What's up with my car?
I'm having a couple of problems with my Mini...
Does anyone have a problem with extreme heat near the gas/brake pedal? Also, the car jerks at a very low speed right. It doesn't happen frequently but it's annoying. |
Someone had heat issue near the gas/brake pedal and I believe they ended up having the car bought back, they could never fix it... :eek2: Haven't heard about the jerking right...
I have this to a milder degree. That area does get uncomfortably hot from time to time in my car.
I don't have the footwell heat problem but I remember reading about it on this forum a year or so ago. Someone figured out that it was caused (at least on their car) by the heater core being too close to the interior panel. I don't remember whether tweaking the heater core positioning was reported to help, but I do seem to recall that someone installed a piece of insulation and said it helped a lot. I'd expect that to be under warranty on an '08 though. Maybe you can use the search feature to find the thread I am thinking of from last summer?
Originally Posted by MyBatmobile
(Post 2803941)
The hotfoot issue is well documented. It was due to a heater core part being in contact with the other side of the driver's footwell (no matter if the heater is off or on). Do a search and it'll come up. One person even used a laser thermometer to document the temp in his car (160 degrees I think!). I would think your dealer could wrap the item with insulation if you're got a problem. I haven't hear complaints about it in 08/09 models though.
Originally Posted by TheBigNewt
(Post 2804853)
| All times are GMT -7. The time now is 04:13 AM. |
