Driver's side window won't roll down =(
I just got my mini on Thursday and everything worked fine. I tried to roll down the window this morning and nothing happened. I tried fiddling with the switch, and opening and closing the door (hoping somehow it would reset something:razz:). Are there any ways to lock one window(like if i accidentally pressed something)? The passenger side still works. I just think it's so strange that it stopped working all of the sudden (good thing i have a warranty). I'm going to take it to the dealer tomorrow but I wanted to make sure it wasn't an error on my part first haha.
Sounds like the motor went, happened to mine as well. Common thing on Mini's.
My '03 MCS would do this intermittently, especially when it was hot and/or humid. A good hard rap with your fist just below the door cup (that's where the motor is) while you cycle the switch will usually free it up. :nod: If this is a brand new MINI (R56), take it back to the dealer.
Yes my '03 Cooper also has this problem. You have rap your fist just where you say to make the window move. I am so used to this I just figured it was a MINI indiosycracy, at 130,000 miles I have done this 100 times and it always ends up working.
thanks for your replies everyone, i'll try it
If it's under warranty, I wouldn't bother hitting it w/ your fist. It might just free it enough so that the dealer won't be able to "duplicate the problem".
It's very common on these MINIs - I had my window motors replaced just before the warranty expired on mine. |
Yeah I'm gunna take it to the dealer. If it does it after the warranty expires, I will use the first trick haha
Rapping it works been doing it for two years but i hit it right above the speaker
I took it to the dealer. I had the extended warranty so i figured why not. 45 min after I dropped it off they call and said they could only cover half because "usually the warranty doesn't go into affect until 30 days after purchase". I called BS and went in to raise hell. Right away a man told me whoever told me that was completely wrong. It still took forever to fix though. Then it was just a matter of if they would get the parts that day. They ended up getting them because i acted so disappointed with the company I think. I also asked for them to make my alarm beep when i lock and unlock the door. (The alarm was included with my mini, or was supposed to be) It turned out there was no alarm on the car (which didn't surprise me because I never saw any blinking lights). They screwed that one up majorly. If I would have never said anything I would be driving around totally oblivious. So the guy promised they'd install it within 15 minutes (stupid promise though, the alarm guys had the day off). Now I have to take the car back again... at least the window works again and I didn't have to pay anything. I got them to give me a coupon for a free oil change and hopefully I can convince them to fill my tank (demand premium of course) and give me a free detail.
Wow, I would have called BS on that too.
So are they installing the OEM alarm, or something aftermarket? |
no dealer will fill your tank. Maybe when you 1st buy it. The early gen mini's being 2002 first yr. Did not come with Factory alarm. I assume there installing an after market unit. You see 2002 were not prewired. Also the 1st gen did not have a sensor to tell you when to replaced your brake pads.
thats also something to keep in mind. And The early gen had Power steering fan motors that would lock up @ times or keep running. Keep that in mind. or they get real noisy especially when your running the AC system. |
Originally Posted by AKIndiMini
(Post 2605787)
Originally Posted by guidmini
(Post 2605799)
Originally Posted by itsminibtch
(Post 2606876)
since i bought it used its going to be whatever aftermarket alarm honda uses. i didnt think to ask for the OEM mini alarm, but i already made the deal.
I'd hate for the dealer to hack into the MINI's wiring... |
(Post 2605799)
Originally Posted by Big Daddy
(Post 2607003)
Both my '03 and '05 MCS had/have brake pad sensors. They are installed on the front left and right rear brake pads and are OEM parts.
My '03 S built 12/02 does not have brake pad wear sensors.
Alan |
man! I'm bumperooing one of my first threads ever!! Anyway... what do you know, now the passenger window is out. There is no way I'm going to get honda to replace it because I demanded my money back for their crappy warranty a long time ago. Where's the best/cheapest place to buy the window motor? How easy is it to install? Thanks NAMers!
No Factory Alarm??
(Post 2605799)
It Worked!!!
I was elated when we tried this and it worked!!
Now when I have to take a ticket to get into the parking garage at the gym, I dont have to open my door to do so. :thumbsup::thumbsup: |
Thought it was just me!!!
My passenger side window rolls up and down, only when it wants too. I thought it was broke, thought it was the motor, then one day just pressed it and it worked. Then I would test it (usually on cold days it works)... not on hot days (which of course is when I actually NEED it to roll up and down). I"m going to try the rap thing... It's kind of like fonzie... lol Hey if it works!!! But I'm thinking since this DOES work, there must be a more permanent fix? Anyone know?
| All times are GMT -7. The time now is 07:03 AM. |
