North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   Stock Problems/Issues (https://www.northamericanmotoring.com/forums/stock-problems-issues-9/)
-   -   Inside air won't turn off (https://www.northamericanmotoring.com/forums/stock-problems-issues/144693-inside-air-wont-turn-off.html)
brianthenewguy Jun 20, 2008 04:24 AM
[FONT=Arial]So my Gas mileage isn't doing to well. I am tryign to weed out the problems. But I have a problem with the inside arif of my car. Even after i turn it off in the center console so that it should be technically off. I am still getting alot of airflow out. In fact the lowest setting on the air is pretty much what I am getting if not more. Does anyone else have this problem? Is this normal? I have a 04 mcs by the way. Thanks for the help[/FONT]
smi2710 Jun 20, 2008 03:06 PM
we can turn off our air circulation if that helps. the light is always lit, i am awaiting a new hvac control piece to try and see if that works or solve the problem. till then we have jsut had the vents closed
brianthenewguy Jun 23, 2008 09:17 AM
Allright. Thanks for the reply. As long as I am not the only one who always has the air circulation on in their mini. It is an odd thing, that even though I turn off the Air, or air conditioning, there is still a pretty large amount of air coming through the vents.
Eric_Rowland Jun 23, 2008 09:22 AM
Do you have manual or auto climate control?
Are you getting air flow even when stopped? If you don't have it on 'recir' you'll still get airflow when moving.
Shouldn't have anything to do with mileage, though.
