Steering fan - doesn't move
normal? noticed it while under the car...doesn't spin freely with the car off. Maybe the fan es kaput?
Just checked mine, all ready up on stands, and it spins, but with a little resistance(?)
yeah...I recall it's supposed to move from when I cleaned deer guts out from under my wife's cabrio.
Originally Posted by PGT
(Post 2159980)
(Post 2159980)
Be really careful about driving it without it working. If the power steering pump gets too hot it dies. That's a $700 round trip at my dealership. Mine went out and we bought the part and husband replaced it. Takes a bit of contortionist moving but it can be done by you.
Also, the big question is has it already started to go bad and should you just replace both now. ugh. Good luck with it. :roll: |
Get that fan replaced ASAP dude, and keep an extra on the shelf for the next time it happens. They die often, mostly from dirt getting in the fan motor; I budget changing mine about every 18 months. The design is super horrible; the fan is such that really heavy debris will fall down into the motor and jam it.
maybe you should consider one of these...
http://new.minimania.com/imagesbig/nma3042.jpg http://new.minimania.com/web/AddedFr.../InvDetail.cfm |
Originally Posted by Ryephile
(Post 2160420)
Originally Posted by cartar452
(Post 2160428)
when i had my pulley installed we noticed that my mini was leaking power steering fluid and the p/s fan was locked up. luckily my repair was covered under warranty. markel ended up replacing the p/s pump and fan. get it done asap!:nod:
i was also looking into getting one of the fan covers. |
I have one of those covers sitting on my shelf in the garage, I was using it on my old PS fan but since I had it replaced with a newer unit that already has a cover on it, I haven't taken the time to install it....it does work well and gives you more protection that the one that comes stock....
(Post 2160750)
the car only has 17k miles on it and is NOT a daily driver. A shame it's gone bad so soon. I have the car up on stands right now....I wonder if the dealer will swap me one over the counter under warranty. It's a PITA to have to leave the car for 1-2 days to get basic things done like this.
Originally Posted by JohnnyG
(Post 2160876)
T
(Post 2160428)
CAUTION: BEFORE TRYING TO WORK ON THE FAN (EVEN JUST TO CLEAR A BLOCKAGE) MAKE SURE THAT THE BATTERY IS DISCONNECTED
(Post 2160428)
we looked this over again. seems it wasn't locked up, but sand/dirt had jammed the blades. cleaned it out and spun free. I couldn't start the car (header is off), so, we'll keep an eye on it once it's back together and get the dealer to warranty if needed.
OK my steering has gone all heavy, so I have been reading about the pump fan and sure enough my is stuck solid. Here are my thoughts.......
My pump is still "whining" so is it dead or could I possibly have a "Rack" issue instead? Would it whine if it was cooked? My dealer wants $900 for parts and labor, which is total Bullshi* if you ask me. If it is my pump, is this something that I could do myself? I'm not a qualified mechanic, however I'm not totally dumb when it comes to fixing/replacing stuff. |
Originally Posted by Muppet
(Post 2179918)
Originally Posted by Xymox
(Post 2185770)
Can you change your own oil? Rotate tires? Change spark plugs or do a radiator flush? If so, then yes, you can handle this task.
(Post 2188516)
ok, that sounds good. I'm taking it to the dealer next week to see what they say the problem is, i have the feeling it's the rack because i can still hear the pump whine. I don't think the rack is something that i could do though
(Post 2188559)
What makes you thik your steering rack is the culprit? For me, the whining is coming from the power steering pump. As soon as it's plugged into a power source, the whine begins. It's a sure sign the power steering pump is kaput.
Well i'm happy to say that it wasn't my steering pump nor my steering rack. I took it to the dealer and they told me that they needed to replace the "steering shaft U joint".
The steering rack would have been $1500 aprox, the pump would have been $900 aprox but the u joint was $250 ! I was VERY surprised to have a dealer fix something for $250 when they already prepped me for $1500 or $900. I have new respect for the MINI dealer now ! |
One note about the fan grill.......it will only stop the large stuff from hitting the fan. The stuff small enough to get into the fan housing will still get by. Jusy get into the habit of checking the fan with each oil change, or as Ryphile suggested, just change it out on a regular basis.
What's the best price you guys are finding for the P/S fan. My mini has 55k and I want to change the fan now even though it appears to be fine.
Thanx |
| All times are GMT -7. The time now is 01:38 AM. |
