I think my hood scoop is melting...
Old Dec 15, 2008 | 11:13 AM
  #301
Juiceman's Avatar
Juiceman
Originally Posted by desertmini21
I have not read all of the 200+ replies to this thread, so I apologize if this has been answered, but have there been any reports of 2009s having this issue?
Probley not enough time has passed yet for any damage to show up????
Old Dec 15, 2008 | 11:50 AM
  #302
daffodildeb's Avatar
daffodildeb
Originally Posted by JCR1960
That is odd as the replacement hood scoop should have been ordered semi opened not fully closed like your original one you had.Then there wouldn't have been any need to remove the screen completely.I would tell your SA to order the correct one instead of trying to modify it.Which should be covered under the factory warranty anyway.
Actually, I think he did. He said it would be semi-open, anyway, and was surprised that it wasn't. That's why he went ahead and took it off entirely, since we'd talked about it.
I'm happy, though--I'd rather not have the problem again.
Old Dec 15, 2008 | 03:38 PM
  #303
scottab36's Avatar
scottab36
Hood Scoop replaced with CF Scoop
I recently had the hood scoop replaced under warranty with the CF scoop by simply paying the difference. I also added additional insulation under the bonnet.
The big piece on the hood is "Dynamat Hood Liner". The smaller piece is" Thermo Tec 13575 Adhesive Backed Heat Barrier (heat rated to 2000 Deg F). I found both on Amazon. Pieces were custom cut to fit.
I also added the M7 Heat Shield!!!
I am hoping this will eliminate any problems with the hood scoop melting. With the addition of the JCW Tuning Kit I suspect the turbo will be producing a bit more heat.
Old Dec 15, 2008 | 06:06 PM
  #304
Benibiker's Avatar
Benibiker
Scottab36,
The insulation looks very professional, did you cut it out in that shape. I'd say you pretty much are guaranteed not to have a melted scoop again!
Old Dec 15, 2008 | 06:16 PM
  #305
daffodildeb
Yes, they look great! Did you do both the insulating material and the metal part or is that the M7 heat shield? How high can the silver stuff go, without burning or doing other nasty things?
Old Dec 15, 2008 | 07:07 PM
  #306
JCR1960's Avatar
JCR1960
Oh okay and I am glad that this fixed the melting problem.
Old Dec 15, 2008 | 07:18 PM
  #307
daffodildeb
Well, let's HOPE it fixes the problem. From what I've read on this and the other scoop threads, though, with the screen removed the temperature really drops.
BTW, the warped scoop made a great dummy gift for the Christmas party's White Elephant exchange.
Old Dec 15, 2008 | 07:25 PM
  #308
JCR1960's Avatar
JCR1960
I am sure it will.
And great idea about the warped hood scoop as a dummy gift.
Old Dec 15, 2008 | 07:29 PM
  #309
daffodildeb
I am sure it will.
Yeah, the real gift was a MINI cap.
I wasn't as lucky with last year's W.E. gift, though. I got an air intake something for an '05. Fortunately, I managed to unload it on another chatline, though at a net loss. Such is life.
(THIS year I got a cup holder...for an R53. Still trying to dump it. Anyone need one?)
Old Dec 15, 2008 | 11:53 PM
  #310
Ken G.'s Avatar
Ken G.
I'd say that's definitely the chrome delaminating from the scoop, it's probably a pretty thick layer if you can't push it down with your finger. That would be consistent with the scoop overheating and drooping like you describe.
I've got an M7 heat shield in place to prevent this from happening again.
Old Dec 16, 2008 | 02:06 AM
  #311
scottab36's Avatar
scottab36
Originally Posted by Benibiker
Scottab36,
Yes. I updated the post. The big piece on the hood is "Dynamat Hood Liner". The smaller piece is" Thermo Tec 13575 Adhesive Backed Heat Barrier (heat rated to 2000 Deg F). I found both on Amazon. Pieces were custom cut to fit.
Old Dec 16, 2008 | 10:26 AM
  #312
daffodildeb
So what's the max temperature the liners will handle?
Old Dec 16, 2008 | 10:37 AM
  #313
david in germany's Avatar
david in germany
Kinda of odd on my 2009, I heard a sound that sounded kinda like a leaky tire on the engine after shut down(ssssssssssssssssssssss). it appears I have a small pump that continues to circulate coolant for a while after shut down. wonder if people with other year models have that also?
Old Dec 16, 2008 | 11:55 AM
  #314
Dr Obnxs's Avatar
Dr Obnxs
Started with the turbo....
with the 07 model year...
Matt
Old Dec 16, 2008 | 12:04 PM
  #315
david in germany
Thanks!
Old Dec 16, 2008 | 03:26 PM
  #316
daffodildeb
Super strange that they would have it on the lot, isn't it? After all, they could hide it for the 2 or 3 days it takes to get another one.
Old Dec 16, 2008 | 04:21 PM
  #317
scottab36's Avatar
scottab36
Dynamat lists it as being heat resistant up to 225`F. I had it installed most of the summer with no problems. It still looks brand new!
Old Dec 16, 2008 | 04:34 PM
  #318
daffodildeb
Wow, that's pretty low. A lot of the guys have taken temps well over that.
Old Dec 16, 2008 | 04:57 PM
  #319
scottab36's Avatar
scottab36
If it were an issue the hood liner would have already burst into flames. There is enough of an air gap between the hood liner and everything else that is does not see any direct temperature even close to 225`F.
The reflective shield reflects the heat away from the adhesive and foam.
I know that my hood stays much cooler now and that is a good thing for paint.
Old Dec 16, 2008 | 06:11 PM
  #320
daffodildeb
Yes, but as I understand it, the high temps (240+ degrees), were measured on the scoop SURFACE, not under the hood.
Old Dec 16, 2008 | 06:21 PM
  #321
scottab36's Avatar
scottab36
I agree with that. The foil facing reflects the heat away!!!
Old Dec 17, 2008 | 11:13 AM
  #322
earlbowman's Avatar
earlbowman
Another Melted Hood Scoop
Add my Wife's 2007 MCS to the melted hood scoop club. Top dead center. Ours came with the partially openned scoop, but no joy. Just noticed it last week after keeping a close eye on it for the last year. Took 14 months but it's definitely there now. I figured Bakersfield summer temps might do the job, but it made it through the summer OK, go figure. Probably fortunate timing, my warrenty is up in another 4000 miles. (Extended Warrenty kicks in after that.) I'll be calling the dealer this week. Ugh!
Old Dec 17, 2008 | 04:15 PM
  #323
daffodildeb
Open scoops also melt. I know of 2 '08's, with open scoops, that have melted. That's 100%, because they are the only '08's I've seen in that club.
You've certainly piled on the miles! Hint--be ABSOLUTELY SURE you have that car in before the warranty expires. I had a BMW 530i that had something go wrong. Can't remember what, but it was a few hundred dollars worth. I called my service writer and told her that I wanted to put it on record, so to speak, until I could get in. She said it had to be in their driveway by the time the warranty expired, or they wouldn't cover it. It was, by about 20 miles...
Old Dec 17, 2008 | 05:32 PM
  #324
earlbowman's Avatar
earlbowman
Yeah, we average 20-25K miles/year. But this thing is so fun to drive we had nearly 30K the first year and much of that was on $5.00/gal. gas. Hate to think what it would have on it if fuel $ was where it is now! Thanks for the heads up on the warrenty notification. I kind of figured that's the way it would go down though. Anyone had a dealer squawk about warrenty issues over a reflective hood blanket or an M7 heat shield?
Old Jan 20, 2009 | 11:03 AM
  #325
NJP's Avatar
NJP
Melting Scoops
tkwasny--thanks for your support. A couple of points:
You mention that there were changes from 2007 to 2008. Are you referring to the "opening" of the scoop grill? If that's the case, they actually did that in mid-07. Unfortunately it didn't make a difference. And I have 2 friends with '08s, and both have had exactly the same degree of deformation that I have, and that has been shown in the photos of this thread. (Their scoops have been replaced, but I don't know how the new ones are faring.)
My second point is that we can't count on BMW/MINI continuing to support us after the warranty runs out, even though we may report it. A case in point: We also have a 2001 530i. Something went wrong on it--I can't remember what, but it was about $250 to repair. We were very close to the end of the line with our warranty, so I called our service writer and told her about it when I made the appointment, figuring that I would preserve our rights. Didn't work that way. I was told that our car had to be in their driveway BEFORE the warranty ran out, or they wouldn't pay for it. And it was--all of TWENTY (20) miles before the cut-off.
Given the scope of this problem, we might not have that hard-line handling, but I'm not counting on it. I plan to replace it now, at Zippeee!'s next oil change--this week or next--and hope that will give me a chance to make sure the next one doesn't go bad before I'm out of luck.
BTW, does anyone know this--if the scoop is replaced, is the "grill" replaced also? Mine has the totally closed type.
When we had our scoop replaced by the dealer (it was deformed from the heat of the turbo)I asked the dealer what if it happens again? Why wasn't Mini replacing it with metal? The dealer said that they were using a different plastic now & did not expect the problem to continue.
