Need help with alignment
Hi, I am going for alignment today and I was wondering if you can help me with what specs to go with. I want my setup for autox and street use. I have H&R RSS coilovers and 22mm swaybar. Thanks in advance.
camber plates?
No I don't have enough money for camber plates yet.
Setting Rear Toe
I have a question specifically related to setting Rear Toe on an R50 Mini Cooper (May 2003 build date). The car is set up per STS rules with H Sport springs, 19 mm rear bar, and Megan Racing lower adjustable control arms.
Anyhow, I want my Rear Toe set at zero, but the actual alignment measurements are: Left: 0.12 Right: -0.07 Total: 0.05 The alignment tech tells me that a special tool is required to set rear toe. However, I cannot find mention of said tool anywhere, and I would like to clarify this before I take it back to the shop. My questions are: Is there a special tool required to set rear toe? If not, is there a trick to setting rear toe? Does anyone have a shop reference for setting rear toe? Thanks!!! |
There is a plate up above where the rear swing arm mounts to the sub frame (just forward of the rear wheel its partialy covered by a plastic shield). Loosen the three bolts on the plate and adjust toe where you want it. No special tool required just a u-joint and extension with a socket (not sure what size).
There is an eccentric socket tool (BMW special tool 32 4 200) that makes it easier
to set rear toe, but it's not necessary, just a little more hit and miss without it to get the setting where you want it. |
Originally Posted by cristo
(Post 1750452)
to set rear toe, but it's not necessary, just a little more hit and miss without it to get the setting where you want it. As for the tool, I checked w/ my local Mini dealer parts guy, and he tells me that BMW does not make the tool. He tells me to check w/ Snap-On to see if they have it. My alignment tech checks w/ his Snap-On dealer, but no luck. I searched online for said tool and found something at Turner Motorsports (or some place like that) for a 3 series BMW, but they tell me it doesn't work for the Mini. Anyhow, do you know a source for the toe tool 32 4 200? |
$41 at pelicanparts. same price at bmwmotorwerks
http://www.pelicanparts.com/cgi-bin/...ILTER_TOOL2=12 The MINI part is 90 88 6 324 200 (in the link above). The BMW part (doesn't fit the MINI) is 90 88 6 323 030. |
