Solo Where does the 2009 John Cooper Works Hard Top fit in?
We know that the (just-a) Cooper falls in to H stock, and that the Cooper S is in G stock. The MINI Cooper S JCW GP fits into B stock but where does the 2009 John Cooper Works hard top fit in to the SCCA classifications? B stock? G stock?
What about a MCS with JCW stage 1 engine and suspension mods?
I see a lot of people talking about how B Stock sucks for the JCW but it seems like an appropriate class to me - in my region (Cenla or Delta Region in Louisiana) a well prepared G Stock Mini with Hoosiers often beats any of the times produced in B Stock and this is with no JCW. We're talking about 350Z's, Rx8's, and STI's - the JCW might not be the winner on a national level as there's obviously stiffer competition in this class but the Cooper S dominates G Stock already so why would it go in that class?
I think you really have to look at the Nationals times to judge the car fairly, since driver skill can be all over the map at local/regional events. I'm no great shakes myself, but I've beaten a lot of cars that are several classes higher at local events.
I think the heartburn with putting the JCW in BS is that it's a pretty big jump from GS to BS, considering that the JCW is a fairly incremental improvement over the stock 'S'. If you look at the other cars in BS, many of them have a huge horsepower advantage over the JCW, and the JCW is the *only* front-wheel drive car in BS. Not that FWD is necessarily a bad thing in autocross, but the MINI also has a well-known tendency towards understeer, so the combination isn't ideal.
So again, I'm wondering if there just isn't national level talent purchasing JCW's for autocross purposes or if the JCW really is just outmatched in the B Stock Class.
Well, seven of the top eight finishers in B Stock at the 2007 championships were driving the RX-8, so I guess it's dominating BS about as well as the MINI 'S' is dominating GS (8 of the top 9).
Looking at the times in BS versus GS, the top BS cars were pretty consistently 1-2 seconds faster, which is significant considering the average times were only in the 33-second range.
So I guess the question is whether or not a prepped JCW is 1-2 seconds faster than a prepped 'S' on a 33-second course, because that's what it would take for it to be competitive in BS at the national level.
What exactly does the JCW kit give you, suspension-wise? Because if the shocks are different, then it's not really giving you an advantage over the 'S', since I don't think anyone at nationals runs the stock shocks anyway.
Wow, 1 - 2 seconds on a 33 second course is fast! I'd say that the JCW is still good for at least a second over the S. Different Springs and Shocks, Upper Strut Brace, Thicker Sway Bar in the front and rear, Bigger Brakes and 18 inch wheel option as well (don't know width but should fit wider than 225), and 40 more horses. This is all speculation on my part but that sounds pretty significant.
There's also been some testing done that shows that a strut brace doesn't do much for the car's rigidity, and I don't see 18-inch wheels as really being much of an advantage because of the extra weight. (Although I'd be curious to know whether the GS cars at nationals are running 16-inch or 17-inch wheels, considering that I think they can run either size. If they're all using 16-inch wheels, that would indicate that the lighter weight is a bigger benefit compared to a larger diameter).
Likewise with the larger JCW brakes - I think they'd be nice for track use, but I don't think brake fade is enough of a problem during an autocross run for the stock brakes to be a limiting factor (especially since the regular R56 'S' brakes are no slouch, considering that they're the same as the first-gen JCW brakes.)
Really, the biggest advantage in the JCW package seems to be the extra 40 horsepower and the bigger rear swaybar. And while I haven't seen dyno charts comparing the new JCW to the 'S', I'm curious how much extra power there really is throughout the rev range, as opposed to just comparing them at the rev limiter. I know with the earlier JCW cars and the GP, a good chunk of the power increase just comes from the increased rev limit - at lower engine speeds, the delta is *much* smaller. I don't know how the course is typically laid out at Natonals, but at most of my autocross events, it's rare for me see anything above 5400 RPM, and I usually only get that high if there's a straight section at the beginning or end of the course.
I guess we won't really know unless a talented driver decides to campaign a JCW in BS sometime in the future, but looking at the JCW upgrades, the shocks and front sway bar don't buy you anything, because those can be (and usually are) replaced under the Stock rules. I don't know how the springs differ, so there might be some benefit there.
I just really am curious about this as I still think that the JCW could be competitive in the right hands, maybe it's still down vs the RX8 but we can't really know without a really qualified driver. There are so fewer JCW's available and national level mini racers will pick a regular S because it is dominant in it's class and I wonder if the JCW is simply getting overlooked as a competitor. Again it's purely speculation on my part and I could be way off, but it's good for conversation none the less
You will probably never find a stock JCW running in BS at the nationals. There's no point to it. The RX8's will clean their clock every time. The factory JCW's have been out for going on three years now, and none at the Nationals yet. Kinda tells you something.
On the local level, the only time I can come close to placing, is if the RX8's stay home.
There was a proposal to move the JCW's to DS, but the SEB squashed it for political reasons. So much for fairness.
I just wonder, in the super competitive world of national autocross does the JCW get completely overlooked by the BStock talent because 7 of 8 top times are RX8's and people buy accordingly? Could it be that it's really not that far behind the rx8 but the little bit it is makes it unappealing to national talent? Or are you completely right in your analysis and the only way to place in B Stock is if the RX8's don't show up?
They talk about the 1 series BMW possibly being the hot ride in D Stock this year and I really have to think that the JCW would clean up in D Stock. Great news for JCW owners if that were to happen! Maybe my Mini enthusiasm goes too far, but I'd rather have a JCW than an RX8 anyday.
I just got info from one of the local hot shoes that drove a RX8 last year in BS.
I ran either 245/35-18 V710's or 285/30-18 A6's. If I was going to run the bigger tires, I'd go with the 295/30-18 A6, which wasn't available when I was running my car actively. The Kumhos last longer and are probably every bit as fast...
For rims, I ran the OZ Ultraleggera which are light (18.4 lbs)and not too expensive, like $300/ea from Tire Rack.
Still, I find it interesting that he's running a 285mm A6 on an 8" rim, considering that Hoosier recommends a 10"-11" rim width for that tire. His tires must look like balloons on those rims.
That's still much wider than I'd recommend for that size rim, but if it works for him, more power to him.
Under the stock class rules with slicks on the R53 you are pretty much stuck with 225's. I have used 225/50/16's with et-42 rims and I got light rubbing on the rear control arms under load. It didn't damage the tire just removed a little paint from from the control arms.
http://www.cenla-scca.org/results/sowdiv1_pax.htm
Note the raw times at the top of the page, paricularly Jeff Schaadt in the GStock Cooper S and Eric Jones in the B Stock RX8. Very, very close - and to be fair, the pax is worse in B Stock than G Stock so Eric Jones apparently ran a better race in theory as he finished ahead of Jeff Schaadt. Now I have to believe that Jeff would have run more than a few tenths of a second faster in a JCW, which would have won B Stock at the Southwest Divisionals. This regional event includes to the best of my knowledge Texas, Louisiana, Mississippi, Alabama, and Arkansas and although it's not nationals it's a better example than just a local event. Also noteworthy is Dan Pedroza in the MX-5 behind them, who Sports Car Magazine is saying is a serious candidate for the win in G Stock this year.
07-16-2020 12:54 PM
12-23-2015 10:36 AM
