How To Maintenance :: Oil Change How-To
#42
>>I'm going to be doing this soon.
>>Can you get to the drain plug without ramps or jackstands?
Check out friedduck's post near the top of this page. It's definitely possible, unless the dealer has torqued the drain plug on so hard that you need to get close to it for leverage. It's within arm's reach of the front of the car.
#43
I changed my oil this weekend for the first time, and it went pretty smoothly, thanks to the info I read on NAM.
Here are a few pics.
My driveway slopes up to meet the garage entrance, so I was able to get away without using ramps or jackstands.
That's my 13mm wrench on the floor at the bottom right.
#44
#45
Has anybody changed their oil after installing an oil plug with nipple?
Because I'm installing a skid plate, I installed an oil drain plug with nipple, so I can just use a plastic hose to drain oil without removing skid plate..
I do wonder if draining thru the smaller diameter of the nipple/hose will do an adequate job of removing old oil--the gunge & crud should be taken care of by the oil filter, right?
So is there ever need to remove the whole plug? Hoping for reassurance...
#46
Nope, none that I heard of but it is possible.
There is another option. A top side oil changer that works through your dipstick for $49.95
http://www.promini.com/products/oilchanger.shtml
You can still removed your oil filter once the oil is drained.
Your changer should be used only for synthetic oil and not mixed with other regular oils.
Yes, It will be OK except for the really slow draining rate. Oil junk is supposed to be microscopic smaller than sand.
Only if you want to drain at a faster rate or if you want to spill oil on the ground.
#47
#49
Originally Posted by MINImotor
The pictures aren't working
Oil Change
I just did it for the first time and it went really well.
#50
The How-to pics all work over on the Webb Motorsports site in the Garage section.
Here's a link to this one:
http://www.webbmotorsports.com/forum...topic.php?t=10
Let me know if you have any questions.
Hope that helps!
Randy
Hope that helps!
Randy
#51
Computer reminder of oil change
:smile: Thank you for posting all the info on changing the oil, my husband has been fretting over the oil in the mini for two months now. He just doesn't think it should go that long. One question though does the cars computer automatically change after you have done this to remind you of the next oil change? Or is that something that needs to be reset at the dealer? thanks again loops
#52
It would be best to leave it alone just so your dealer doesn't have a reason to whine.
It can actually be done at home but don't.
#53
Originally Posted by obehave
Reset by the dealer.
Edit - I think this is the procedure in this thread is the one I used https://www.northamericanmotoring.co...=service+reset
Nik
#55
#56
#57
Originally Posted by meb
On my 8th oil change. The last one didn't go so well; the O ring apparently broke while screwing the filter housing back together. Upon starting the car to check for leaks, I found one...rather large. Did it all over again. Never had this happen in 1.5 million miles of driving.
Don't know if this is true for you, I'm just throwing this out.
Make sure you prelube the O-Ring. A couple drops of clean oil do just fine.
#58
#62
according to http://www.onlineconversion.com/torque.htmthe conversion is
25 Nm = 18.43 Lb-ft (for the oil filter housing)!!!!
Drain plug = 31 Nm, or 22.86 (23) Lb-ft
Marty
Marty
#63
Marty
Marty
Thanks for the quick catch MartyR.
#64
Fitting Filter in Housing
Randy (or anyone),
Using your instructions, I have managed to remove and install the oil filter casing (I removed the casing so I could re-inforce the center prior to tapping a thread for an oil-pressure sender). Like most users I experienced the first time challenges of lining-up the casing (hand tight) on re-installation.
However, I am a little concerned if I installed the new filter in the casing correctly. Since I was originally having difficulties lining up the casing by hand, I decided to push the new filter tightly into the casing prior to fitment
Will having the filter fitted tightly on the casing cause any oil circulation issues in my car? My car is an 02 MCS with a filter like that shown in Randy's instructions.
Appreciate your comments or advice.
DFD
DFD
#66
#68
That's funny cause I sheared off a brand new set of Harbor Freight tools--13mm wrench the first time I tried to remove my drain plug bolt---after the dealer did an oil change. I then used an impact wrench with a max 250ft pound pressure---had to hold it for about a minute before the bolt came off.
Obviously the dealer didn't put it back to spec!
I replaced mine with a Fumoto valve so I'll never have to worry about it again.
Richard
Richard
Marty
Marty
#69
#72
#73
Originally Posted by MiniKJ
This is such great information. BIG thanks. However, I have not yet read any thread mentioning the procedure for oil change with chrono pack. Is everything identical to those without Chrono pack? It will be extremely helpful. Thank you very much.
#75
Is hand tightling good enough to torque the filter to 18ft-lb? I don't think there's room for a socket and a torque wrench in that space.
I used a Craftsman "1/2 in. Drive Ratchet, Flex-Head Fine Tooth" (linking to the Craftsman site didn't work) with a 36mm socket, and was able to advance the threads about 2 clicks at a time, then verify the final setting with a torque wrench. It was tedious, but MINI didn't leave us much space.
#76
#77
#78
The other thing I notice is it's difficult to find a 1/2" torque wrench that goes to such low setting (18 ft-lb) since I am only able to find 1/2" 36mm socket. Does anyone have advise? I don't believe dealer service department use torque wrench at all.
#80
