FS:: 2004 Mini Cooper S
2004 Mini Cooper S
Year: 2004
Model: Coupe
Price: $2400
Mileage: 100700
Color: Silver
Location (Region): NorthWest
Modifications within the last 10k miles:
Bytetronik Full Access with Data Viewer
Alta 15% percent supercharger pulley
Detroit tuned bypass valve
Lowering Springs with adjustable control-arms
Window Tint
Maintenance within the last 10k miles:
Front/rear Bilstein Shocks
Federal ss595 tires all 4
Clutch replaced
New brakes/ rotors
Battery
Oil Cooler Gaskets
Oil pan gasket
Valve cover gasket
Crankshaft o ring
Air intake filter
Front and rear sway bar bushings
Power flex control arm bushings
Outer ball joints
New spark plugs/ coil wires
Strut towers
LD pump
Windshield wipers
Intake air duct
Vacuum lines
Coolant, brake fluid flush
Idler pulley
Belt tensioner/ Belt
Front Motor Mount
Lower engine Motor Mount
Outer/ inner tie rods
Drivers side axle
Wheel Bearings
Fuel Filter
Transmission Fluid
Royal Purple Oil change every 3k miles
tonyferrari
MINIs and Minis for Sale (archive)
05-07-2008 02:52 PM
Rick-Anderson
10-04-2007 07:07 PM
mr. jim
06-06-2007 07:03 AM
