FS:: Velocity Adjustable Throttle Booster System - $180 Plus Shipping
Old 03-14-2018, 12:23 PM
miniac78's Avatar
miniac78
miniac78 is offline
Price: $145
Location (Region): West
Installation is a breeze with the use of MINI OEM connectors, taking less than 10 minutes.
The Velocity Throttle Booster can be turned on and off to switch between the factory throttle setting and 4 selectable throttle presets. Each of the four throttle presets increases the responsiveness of the throttle from "mild @ 1" to "WOW @ 4," all are a noticeable difference. It gets scary fast! But also gets back to normal depending on what you want.
Using proprietary vehicle data monitors, the Velocity Throttle Booster (VTB) analyzes information and varies the opening angle of the throttle according to the throttle strength selected. Internal memory stores the driver's last selections so that the vehicle turns on in the same setting as when it was shut down.
Features:
- 4 power profiles selection (min, medium 1, medium 2, maximum 4), adjustable by the touch of a button on the control panel (+ or - )
- Unique “On/Off” button allows users to switch off the unit if they want to drive the car in factory mode
- Built-in memory function that retains last preset setting upon powering on
- Immediate throttle response to the engine in real-time, resulting in faster throttle response.
- Simple “plug-and-play” using MINI OEM Connectors, with no other modifications required
- Slim and Compact design
- Easy to completely remove from vehicle if necessary
Attached Thumbnails Velocity Adjustable Throttle Booster System - 0 Plus Shipping-20180314_111715.jpg   Velocity Adjustable Throttle Booster System - 0 Plus Shipping-20180314_111647.jpg
Old 04-12-2018, 09:04 AM
miniac78's Avatar
miniac78
miniac78 is offline
bump
Old 07-09-2018, 05:22 PM
miniac78's Avatar
miniac78
miniac78 is offline
Still available
Old 08-05-2018, 08:41 PM
TheZeroHero2012's Avatar
TheZeroHero2012
TheZeroHero2012 is offline
Is this still available?
Scooter-09'MCS
08-04-2013 05:49 PM
mikemc
05-20-2010 09:45 AM
Marwan
02-14-2010 06:10 AM
Quick Reply: FS:: Velocity Adjustable Throttle Booster System - $180 Plus Shipping
