FS:: JB+ Adjustable dial inside, not California compliant. Will trade for sprint booster
Old 02-03-2017, 06:42 PM
Chad Morin's Avatar
Chad Morin
Chad Morin is offline
Thumbs up JB+ Adjustable dial inside, not California compliant. Will trade for sprint booster
Price: $230
Part fits (you may select multiples): R50, R52, R53, R55, R56, R57, R58, R59, R60, F55, F56
Location (Region): Midwestern
JB + Adjustable dial inside, not California compliant. Will trade for sprint booster for mini countryman with Manual transmission only. JB Plug In Tuning Module 2011+ Turbo N18 Engine. Used less than 4 months. Looks new. All contacts clean, grommets soft, wires soft. This one is not California compliant. It has a dial that can be turned to meet your mods or dialed back if you just use premium gas. I have it on 75 and added high octane and royal Purple boost. Turned it back to 60 for new owner. Two screws and you can change it to whatever you want.Decided to go with manic tune. Saving for larger intercooler and then down pipe. If nothing to trade performance wise I'll take $230 including shipping USPS lower 48 only. Note: This is Pre Cali law so it is better than Cali conformed JB+ you see from Burger on Ebay.
Attached Thumbnails JB+ Adjustable dial inside, not  California compliant.  Will trade for sprint booster-img_0444.jpg   JB+ Adjustable dial inside, not  California compliant.  Will trade for sprint booster-img_0445.jpg
Old 02-03-2017, 08:07 PM
Minnie.the.Moocher's Avatar
Minnie.the.Moocher
Minnie.the.Moocher is offline
F series no good with JB
Old 02-04-2017, 05:16 AM
potxoli's Avatar
potxoli
potxoli is offline
PM Sent
Old 02-05-2017, 01:53 PM
BaitoSamurai's Avatar
BaitoSamurai
BaitoSamurai is offline
Little off topic but how do you adjust it? I don't see anything in the pictures.
Old 02-05-2017, 01:56 PM
MarioKart's Avatar
MarioKart
MarioKart is offline
Vendor
You open the JB+ and use a small screwdriver to turn a small dial on the board. Can be done in under one minute
mQubed Motorsport, Manic Tuning Dealer
Old 02-22-2017, 09:23 AM
DDRKSDE's Avatar
DDRKSDE
DDRKSDE is offline
PM sent
Old 04-02-2017, 04:55 PM
the_redpill's Avatar
the_redpill
the_redpill is offline
PM sent.
Old 04-02-2017, 06:34 PM
rob.james.arias@gmail.com's Avatar
rob.james.arias@gmail.com is offline
Won't work with F56 will it?
Old 04-02-2017, 10:23 PM
MarioKart's Avatar
MarioKart
Vendor
No, but I sell new ones that work for the F series
Old 04-03-2017, 09:14 AM
Chad Morin's Avatar
Chad Morin
I sold the California compliant one and decided to keep the one MarioKarts friend hooked me up with. I had issues at first but once I replaced my plugs and ignition coils, all was well. My car had 50,000 miles on it. Minis should have their plugs swapped every 30,000 as suggested by many but not mini. I stopped throwing codes, set the dial at %50 and use premium shell gas and every once and awhile I use royal purple boost gas additive and alternate with a little MMO. I also swap my oil every 3000 with 5-30 Royal purple or Mobil 1 depending on the DIY sale at o'reileys or AutoZone. Once you get used to having a JB+ You will miss the boost it gives. This summer I plan to go with a new exhaust and ECU flash and down pipe. You can trust MarioKart. Also I hear buying a larger intercooler is a must. Is that true Mario?
Old 04-03-2017, 12:58 PM
MarioKart's Avatar
MarioKart
Vendor
Hi Chad, The ECU tune is way more aggressive, but has more safety features than the JB+. I encourage customers to get a bigger IC, it adds consistent power and peace of mind.
Old 04-03-2017, 01:02 PM
the_redpill
I'm going to go with Mario on this. Mario, thanks for taking your time to help out a Newb. I'm going with 2 stage tune, Ceramic Coated DP and Wagner Intercooler per your advice! Will be shipping ECU off next week to you.
