WTT:: RACECHIP 4 CravenSpeed Big Pair
Old 05-04-2017, 04:51 PM
LormaD's Avatar
LormaD
LormaD is offline
Category: Suspension
Price: $1
Part fits (you may select multiples): R50, R52, R53, R55, R56, R57, R58, R59, R60, F55, F56
Location (Region): Canada
Item Condition: Brand New
I think I will inquire about how to offer a group buy instead...
there is obviously interest, but I am not prepared to go down the route of fielding 1million questions.
stay tuned.
Old 05-05-2017, 06:43 AM
darkboost's Avatar
darkboost
darkboost is offline
How does race chip work? Is it a piggyback, if so wont the ecu just learn over it?
Old 05-05-2017, 08:00 AM
LormaD's Avatar
LormaD
LormaD is offline
Since the Dawn of Turbo Engines...
For the longest time, turbo charged engines controlled by ECU's have been modded by suppressing the actual boost pressures generated.
By default a parameter is programmed to open the wastegate and limit boost pressure to a predetermined setting. If the actual boost measured is controlled (by the piggyback ECU) to output a value lower than actually being produced, the engines computer will compensate accordingly.
More boost is a byproduct of more air (fuel mixture would be lean), more fuel (injectors remain open longer), hence more power.
The plus is that it is an easy way to get an extra 50hp or more without physical parts and much labour. Completely reversible, and since the engine has it's own built in safety parameters, completely safe in the hands of 99% of the people.
Cheers
Old 05-05-2017, 01:29 PM
Bnourai's Avatar
Bnourai
Bnourai is offline
hi, so you will have an additional 30-40HP at your disposal, will there be any controllers or its continues?
thx
Old 05-05-2017, 01:58 PM
LormaD's Avatar
LormaD
LormaD is offline
it's supposed to be 55ish hp
It is controlled by your right foot :D
Old 05-05-2017, 02:09 PM
Bnourai's Avatar
Bnourai
Bnourai is offline
lol,have sent you a pm
Old 05-06-2017, 06:08 PM
MAGICIAN's Avatar
MAGICIAN
MAGICIAN is offline
Racechip
How does this compare to the accessport? Or is it about the same?
Old 05-07-2017, 10:11 AM
bmalay's Avatar
bmalay
bmalay is offline
Do these work on N18?
Old 05-16-2017, 06:33 PM
Quintin Magill's Avatar
Quintin Magill
Quintin Magill is offline
PM sent
