FS:: Alta Access Port with Perrin Stage 4 Tunes
Old 12-09-2016, 03:46 PM
Dr. Spade's Avatar
Dr. Spade
Dr. Spade is offline
Smile Alta Access Port with Perrin Stage 4 Tunes
Category: Brakes
Price: $700
Location (Region): SouthEast
Selling my AP with 10 additional Stage 4 Tunes.
Stage 4 Originally designed for the Alta 42/56 turbo. But JMTC and Frankenturbo sell a very similar unit.
AP has maps for S and JCW.
Old 12-14-2016, 12:41 PM
Dr. Spade's Avatar
Dr. Spade
Bump. Also has a couple extra Stage 3 maps
Old 12-21-2016, 06:50 AM
Dr. Spade's Avatar
Dr. Spade
Price dropped to $750
Old 03-07-2017, 09:01 AM
Dr. Spade's Avatar
Dr. Spade
Up...
Old 03-14-2017, 10:47 AM
Dr. Spade's Avatar
Dr. Spade
bump
Old 03-14-2017, 11:17 PM
minicountry's Avatar
minicountry
minicountry is offline
Does this works with Mini Countryman S?
Old 03-21-2017, 08:00 AM
Dr. Spade's Avatar
Dr. Spade
With an N14 motor yes.
Old 03-22-2017, 06:56 PM
sgscomps's Avatar
sgscomps
sgscomps is offline
Accessport only work on the N14 engine. I believe the Countryman has the N18 so it won't work
Old 04-04-2017, 11:57 AM
Dr. Spade's Avatar
Dr. Spade
I think you're right, N18 started in 2011 anyway, at least for S.
Old 04-05-2017, 10:27 PM
alwayzspeedin's Avatar
alwayzspeedin
alwayzspeedin is offline
I'm assuming it's unmarried. ?
Old 04-26-2017, 09:07 AM
Dr. Spade's Avatar
Dr. Spade
Yes it's already unmarried
Old 05-26-2017, 05:48 AM
Rice_in's Avatar
Rice_in
Rice_in is offline
Still available?
Old 05-26-2017, 08:40 AM
MAGICIAN's Avatar
MAGICIAN
MAGICIAN is offline
Accessport
Can you give me some more info on the additional maps? Thanks
Old 08-31-2017, 08:36 AM
Dr. Spade's Avatar
Dr. Spade
ACCESS PORT HAS BEEN SOLD
However if you are looking for the additional Stage 4 maps, please PM me.
Old 08-31-2017, 05:39 PM
MAGICIAN's Avatar
MAGICIAN
MAGICIAN is offline
Can you tell me more about your stage 4 maps.
Thsnks
Old 09-06-2017, 11:43 AM
Dr. Spade's Avatar
Dr. Spade
PM'd.
I have Stage 4 maps from Perrin for both S and JCW. It is made for a Stage 3 car with the addition of a slightly larger (42MM) turbo.
Old 01-25-2018, 08:46 AM
bbm's Avatar
bbm
bbm is offline
I have a 2007 mini S with N14 engine. I have anALTA AccessPort but need a Stage 4 tune program. I have every Alta upgrades you can think of, plus a recently added a bigger turbocharger from JMTC with 46mm compressor fan. But now my current set of Accessport tunes does not do it justice. I need a tune that will optimize my bigger turbocharger to unleash its full potential. Do anyone have a tune that I can upload?
Old 01-25-2018, 08:51 AM
bbm's Avatar
bbm
bbm is offline
Addendum to above quote. Stage 3 or 4 ALTA AccessPort tune WANTED. To support Alta upgrades and 46mm JMTC Turbo upgrade.
Old 01-25-2018, 01:45 PM
MAGICIAN's Avatar
MAGICIAN
MAGICIAN is offline
BBM I will be upgrading my turbo this spring and will be in the same situation as you. I just spoke to ARRIC which you should do. They have a tune specifically for your set up. You won’t be using the accessory anymore. They built my single mass / Kevlar clutch.
So I’m ready for my upgrade this spring.
Old 01-25-2018, 02:55 PM
bbm's Avatar
bbm
bbm is offline
I spoke to Arric and he is recommending his powerGate. I will mostly likely get it from him. I also have his JMTC performance clutch.
Anyway since I already have the Accessport and since Dr Spade mentioned that he has the stage 3 or 4 map available. I am assuming his willing to share it. If so I certainly would like to try Dr Spades maps.
Personally I have 20 Alta Accessport stage 2 maps I’m willing to share for R56 n14 Mini’s. 10 maps that runs 91 oct fuel and 10 maps that runs 92+ oct.
Old 01-25-2018, 03:00 PM
bbm's Avatar
bbm
bbm is offline
By the way Magician thanks for the tip and please keep in touch. I would like to know how yours turn out. Any advice is much appreciated
Old 01-25-2018, 03:37 PM
MAGICIAN's Avatar
MAGICIAN
MAGICIAN is offline
That’s a lot maps. I’m running stage 3 on my accessport currently. Please tell me you feel a big difference with the upgraded turbo.
Phil
Old 01-25-2018, 03:40 PM
MAGICIAN's Avatar
MAGICIAN
MAGICIAN is offline
ARRIC just told me he’s trying to get the map for a less expensive price. I’m hoping by the time I do mine it will be less than expensive.
Old 01-26-2018, 07:36 PM
Dr. Spade's Avatar
Dr. Spade
I will PM you guys re: maps
Old 01-27-2018, 08:23 AM
MAGICIAN's Avatar
MAGICIAN
MAGICIAN is offline
BBM I know the stage 4 upgrade is a great deal. My question is will it take advantage of all the other upgrades you’ve done. JMTC map will be or supposedly designed for all the upgrades we’ve done. I have the AEM CAI which I feel is the best on the market. When he designs my map I’m expecting he or the designer knows how to take advantage of that upgrade. As with all the others. The accessport has is a canned tune for the general public. Now if you and I have the exact upgrades and that map had been tested. You will then see a big difference. You know where I’m coming from. My goal for my mini was 300hp with out internals. My car is a 09’ JCW and started with 208. My estimate now is roughly 250-260 with my mods. ARRIC said with his upgraded turbo and his map 300 is possible. Time will tell. Try to dyno before and after. This way you really know.
