WTB:: oil filter housing
Old 12-31-2017, 05:46 PM
vulkandino's Avatar
vulkandino
vulkandino is offline
oil filter housing
Price: $50
Location (Region): West
Purchased new oil filter housing. Thank NC TRACKRAT
While replacing my oil filter on my GP with 107k miles I noticed the drain plunger was loose. One of the three clips is broken. Being that these aren't sold separately from the housing I'm looking to purchase a used housing with or without the heat exchanger. I'm only interested in the updated design.
Old 12-31-2017, 08:17 PM
Hot.Damn.'s Avatar
Hot.Damn.
Hot.Damn. is offline
I might have one, I’ll check tomorrow and PM you if I do.
vulkandino (01-03-2018)
Old 12-31-2017, 09:02 PM
vulkandino's Avatar
vulkandino
Great, I appreciate it.
Old 01-01-2018, 01:14 PM
vulkandino's Avatar
vulkandino
Anyone?
Old 01-01-2018, 01:32 PM
NC TRACKRAT's Avatar
NC TRACKRAT
NC TRACKRAT is offline
Yep! I have a brand-new complete assembly. sending you a pm.
Old 01-03-2018, 10:23 AM
sarom058's Avatar
sarom058
sarom058 is offline
Location: Portland, OR *currently in a temporary email address
Anyone have another? Same thing happened to me...
Old 01-03-2018, 08:08 PM
vulkandino's Avatar
vulkandino
PM Hot.Damn. he should still have a housing for you. Also NC TRACKRAT might have more then one housing. G/L
Old 01-04-2018, 06:48 AM
NC TRACKRAT
Sorry, no. vulkandino got my last one.
Old 01-04-2018, 11:33 PM
Hot.Damn.'s Avatar
Hot.Damn.
PM replied
Old 01-06-2018, 06:48 PM
dhabutcher's Avatar
dhabutcher
dhabutcher is offline
Housing Fix
https://www.northamericanmotoring.com/g/album/3806575
a slot can be cut with a tiny cut off wheel on a dremel tool, to accept a C Clip to retain the drain valve
About 4 cans of brake clean to clean housing out, Have been running this for several years no problems
sarom058 (01-08-2018)
Old 01-08-2018, 08:27 AM
sarom058's Avatar
sarom058
sarom058 is offline
This is incredible!! Thank you so much. Will definitely be trying this.
Old 08-22-2018, 11:45 AM
Mini860's Avatar
Mini860
Mini860 is offline
Can’t PM you because your mailbox is full
Old 08-22-2018, 05:37 PM
drea-min's Avatar
drea-min
drea-min is offline
OutMotoring is selling the drain back plunger.
Old 08-22-2018, 05:38 PM
drea-min's Avatar
drea-min
drea-min is offline
Old 09-18-2018, 09:31 AM
JDM_'s Avatar
JDM_
JDM_ is offline
Are there any instructions for installing this? Do you remove the whole housing or can it be done while its on the car?
Old 09-18-2018, 10:31 AM
sarom058's Avatar
sarom058
sarom058 is offline
Without ever having worked on the oil filter housing, I think it would be pretty difficult to install this correctly without removing the housing. Although removing the housing while the engine is in the car is a pain too...so I see both sides of this.
I mean, in principle, you absolutely could do it in the car, but you will have no line of sight to the innards of the housing. If you can get your hands on a camera with a cable, or can use some combination of light & mirrors, you should be able to get a good enough view to make sure you got all the pieces out. Bear in mind that if you're installing the new plunger while the filter housing is still in the car, you should not use any brake/engine cleaners on the housing. You only get to clean the housing if it is off of the engine—brake cleaner mixing with oil is probably not a good idea.
The installation procedure with the housing on the car is relatively simple: (bear in mind I opted to replace the whole housing when my engine was out, as my drainback valve broke before there was a replacement online, so this method is untested—but I don't see why you couldn't do it this way)
  1. Drain oil
  2. Remove filter cap
  3. Remove filter
  4. Pick out broken pieces of drainback plunger
  5. Carefully clip the new drainback plunger into the circular hole (see one of the early posts in this thread for a picture of its location—the three plastic "legs" of the plunger just clip over a lip inside the circular drainback hole)
Also, if your oil pan gasket is leaky, it's probably not a bad idea to drop the oil pan and disassemble/clean the oil pickup tube, and put a fresh gasket on the oil pan as well. When I had some similar issues a few years ago, I found some plastic bits stuck in the oil pickup against the screen.
Good luck & keep us updated!
JDM_ (09-18-2018)
Old 09-18-2018, 10:32 AM
vulkandino's Avatar
vulkandino
https://www.outmotoring.com/oil-filt...rep_12345.html
Old 09-19-2018, 05:59 PM
JDM_'s Avatar
JDM_
JDM_ is offline
  1. Drain oil
  3. Remove filter
Thank you.. This helps!!!
trwxxa
11-23-2016 01:28 PM
fenderpicks
08-08-2016 10:52 AM
ksmaas1
07-10-2016 07:09 PM
knuckleheadbob
01-09-2014 02:57 AM
BChili
10-11-2011 08:53 PM
Quick Reply: WTB:: oil filter housing
