Diagnosing Coolant in Oil
Old 01-14-2019, 01:01 PM
Tgriffithjr's Avatar
Tgriffithjr
Tgriffithjr is online now
Glad to hear it. First time I saw that under a cap I freaked until I figured out it was just condensation.
Old 01-15-2019, 07:25 AM
MINI33342
MINI33342 is offline
Originally Posted by Racingguy04 View Post
Yes, I'm running a catch can, The M7 can plumbed according to M7's recommendations (and I'm aware of M7's reputation).
Out of curiosity, I checked the cap on my wife's 4runner today. It's a completely different car and engine (V6) but driven and stored in basically the same conditions. Her car also has a bit of sludge on the oil cap. So I think between that and the negative block tester test, it's most likely condensation. For now I think I'll just keep an eye on it, and reevaluate once the temps warm up (since I can't plan on the humidity dropping, this is Maryland after all....)
If you did it as per M7 instructions, you did it wrong. The can needs to be connected only to the PCV line and then back to the hard line under the IC. Change it, mine did the same thing yrs ago and I had it as per the Alta instructions (similar to M7). Changing it to the correct way solved the problem. Have had the can installed for 12-13 yrs now with no issues.
This is the correct way to install it.....
https://www.northamericanmotoring.co...an-how-to.html
Old 01-16-2019, 10:08 AM
Black Forest's Avatar
Black Forest
Black Forest is offline
Originally Posted by Tgriffithjr View Post
Here’s a great pic illustrating the different locations of possible head gasket leaks and the resulting effect on symptoms.
Great illustration! Im on the verge of pulling the head on a friends R53 due to coolant in the oil. No oil present in the cooling system. Illustration makes sense.
JDM_
12-21-2018 02:25 PM
Rcaffey2
03-10-2018 08:06 PM
jfrankjr
11-19-2017 07:30 AM
Matthew Hardesty
05-18-2017 11:00 AM
05JCWS
16
09-18-2003 06:40 AM
Quick Reply: Diagnosing Coolant in Oil
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
