FS:: Hsport,Alta, Aquamist,HPFP
Old 02-13-2018, 06:25 PM
randeez's Avatar
randeez
randeez is offline
Quaife, JMTC Clutch, Alta Exhaust, HPFP ++
Category: Suspension
Price: $5555
Location (Region): SouthEast
Car is going back to stock, I've started pulling parts off and will update as items are removed. Prefer local sales but will ship - ALL SHIPPED PRICES ARE CON US, So far I have out:
SOLD!$800 shipped - JMTC "Stage 4" clutch, about 1500 miles on it. N18 only. 26lb single mass flywheel, +15% pressure plate, 6-puck ceramic disc.
http://jmtcperformance.com/stage-1-t...rent-r-series/
SOLD!$700 shipped - Quaife QDF38Z Limited Slip differential. been installed for about a year, about 5k miles. timken bearings pressed on the ends. will include the shells as i didnt bother to have them pressed out/in the case.
https://www.waymotorworks.com/quaife...ferential.html
$650 Shipped - Alta 3" Downpipe Back exhaust - On car for about 2 years, Vband clamps have been swapped (included clamps were trash) ones a vibrant quick release - the other a ticon. OEM clamp worked the best connecting to down pipe. Front hangers had to be cut off and welded back in the correct place - I will probably clean them up and put a nice coat of high temp paint on it. Has been on car problem free, Tips clean up easily. Will make a good deal if local, really dont want to ship
http://altaperformance.com/i-1400713...bo-engine.html
$400 shipped (since it seems the price of these has come down) - N18 2010-12 High Pressure Fuel Pump. Bought from ECS tuning Jan/2017, genuine MINI. Was troubleshooting some issues with my car (out of extended warranty) bought another one only to find out it wasn't the problem. So now i have two that work fine, less than 5k miles.
https://www.ecstuning.com/b-genuine-...e/13517592429/
SOLD!$160 Shipped - Turbo Smart TS-0203-1252, used a few months, comes complete.
http://www.turbosmartdirect.com/Prod...umb-Back.html#
SOLD!$60 shipped - Integral Audio X9331 T-harness. provides 2 sets of RCA outputs, installs behind driverside kick panel. pretty sure integral audio is no longer making these - caught last limited run of them made
https://www.northamericanmotoring.co...available.html
SOLD!165 +shipping - Hotchkis H-sport Comp 25.5mm rear sway bar. Been on car a little over a year, only set in the third position. Has rubbed in a few places - noticed after taking off, never any noise out of it. bought from WMW
https://www.waymotorworks.com/h-spor...-sway-bar.html
SOLD!175 +shipping - Hotchkis H-sport rear camber links. On car for a little over a year. One is pretty clean, the other has a few wrench marks on the adjusting link. bought from WMW. picture shows 1 90* grease zerk broke i will replace it
https://www.waymotorworks.com/h-spor...ber-links.html
SOLD! 950+Shipping - Howerton Aquamist HFS-4 V3.1 with 1gal tank for R56. On car for about 6 months, only used VP racing fuels meth and distilled water through it. red led gauge, all connectors perfect, no cables shortened when i installed so plenty of length for any mini. gauge is mounted in craven speed vent pod will include if wanted. The PTFE pipe is very inexpensive. I can include what i have but I would probably replace it with new for piece of mind 6mm from pump to FAV, 4mm from FAV to jet. Only thing not included is a few misc positaps and ring terminals. has .8,.9,1.0 jets, 4mm check valve, 90* fitting for 4mm tubing, i think i have an extra jet adapter and plug, HFS4 manual, howerton instructions. If local I have little bit of meth left I'll throw in.
http://howertonengineering.com/produ...kit-with-tank/
https://www.cravenspeed.com/mini-ven...xoCB5MQAvD_BwE
adding pictures....
Old 02-13-2018, 06:26 PM
randeez's Avatar
randeez
randeez is offline
Old 02-13-2018, 06:28 PM
randeez's Avatar
randeez
randeez is offline
Old 02-13-2018, 06:31 PM
randeez's Avatar
randeez
randeez is offline
Old 02-13-2018, 06:34 PM
randeez's Avatar
randeez
randeez is offline
Other stuff that will be for sale when i get around to removing:
SOLD! Megan Coilovers, a little over a year old, only ran with about 1.5" drop. Soon as i pull the front and make sure all is good. maybe $450?
Ebay intercooler, dont really remember what i paid. fits good, no issues, ran 20+ psi thru it for over a year. maybe $125? I'll throw in the alta muffler delete pipe (red)
Turbosmart full recirc valve- TS-0203-1252 used for a few months comes with boost adapt, some lines, resistor for stock electrical connector. $150
Milltek Downpipe , catless $150?
If anyones interested in the gpop hybrid turbo? has about 15k miles, no shaft play - big + if you have a stock turbo somewhat working to swap+cash
and if turbo gets sold and i'm that far into it i have the WMW/JCW manifold I can pull it off also.
Driverside axle, for manual car- genuine mini, maybe 3k miles, ended up with an extra one of these also. car developed the acceleration wobble, figured it was going out so i bought a new one. When i went to replace it, the one in there wasn't even seated in the transmission, i swapped them and pulled a boot on the old one anyway to inspect. New one just has a pry mark or two on the transmission side to get the clip out. 350?
Old 02-13-2018, 11:16 PM
RaymondS's Avatar
RaymondS
RaymondS is offline
edit // stepping out of line.
Old 02-14-2018, 12:58 AM
Peter Tran's Avatar
Peter Tran
Peter Tran is offline
I am semi- interested in the gpop turbo. how much were you thinking cash plus stock turbo. Mine has no shaft play at all. Runs perfect.
Old 02-14-2018, 04:13 AM
SoundedAlarm's Avatar
SoundedAlarm
SoundedAlarm is offline
Aquamist and rear camber arms
PM'd on aquamist and rear camber arms
Old 02-14-2018, 07:23 AM
randeez's Avatar
randeez
randeez is offline
Originally Posted by RaymondS
If it's for the R56, can you shoot me over photos of the intercooler and alta hotside boost pipe? I need that.
Is it the full TS-0203-1252 kit or is anything missing? I will take that too.
I will pull the IC and tube this afternoon if i get home early enough.
The turbosmart, I should have everything for it minus the smaller fitting that threads into the boost adapter for a separate boost gauge (do not have one so adapter has larger fitting and plug in other port). i will look for it though, and i will throw in some new tyraps
https://c1552172.ssl.cf0.rackcdn.com/884417_x600.jpg
Old 02-14-2018, 07:24 AM
sidesswipe's Avatar
sidesswipe
sidesswipe is offline
interested in the coils, how were they when you drove with them?
Old 02-14-2018, 07:35 AM
randeez's Avatar
randeez
randeez is offline
Again I will gladly keep you first in line, but I would like to remove, give it a good once over before selling.
Gpop rebuild was $780+ turbo, manifold is $450
Let's call it:
$700 turbo+manifold
$500 turbo
$500 turbo+manifold+working turbo core
$325 turbo+working turbo core
https://www.waymotorworks.com/turbo-...5-r56-r57.html
Old 02-14-2018, 05:05 PM
randeez's Avatar
randeez
randeez is offline
SOLD!450+shipping- , Coilovers out and cleaned up a little bit, all the top mounts are still tight, also have the adjustment wrenches and dampening extensions for the rear.
100 shipped - Also have a set of adjustable front endlinks from WMW
https://www.waymotorworks.com/wmw-ad...-endlinks.html
550 shipped - coilovers and endlinks together
Old 02-15-2018, 05:45 PM
randeez's Avatar
randeez
randeez is offline
Intercooler and turbo muffler delete pipe - both are pretty rough. If someone really wants them make offer. both functional $125 obo
Intercooler has cast aluminum ends, rolled beads on the in/out, side tabs line up with stock mounts, on my car the top tab didnt hit anything and wasnt used. At some point it looks like it took a pretty nice shot from something on the road, has a patch of the fins laid over- prob about an inch long on one row, 1/2 inch long on the row under it.
Pipe, has a few issues. where it connects to the turbo the inside silcone is coming off a few small spots about 3/4" in, the groove on the compressor discharge is about 1-1/4 in, so i doubt it will really effect anything. I used a tclamp instead of a hose clamp on it, probably put a little to much pressure. small slit on the outside not deep, a little chunk out of the pipe about half way down maybe 1/4" long, through 1st layer of silicon - pipe is 5ply thick
Old 02-15-2018, 05:46 PM
randeez's Avatar
randeez
randeez is offline
turbosmart
$150
Old 02-16-2018, 06:06 AM
YLWR56's Avatar
YLWR56
YLWR56 is offline
PM sent about coilovers
Old 02-16-2018, 03:28 PM
randeez's Avatar
randeez
randeez is offline
Coilovers and links are SOLD!
Old 02-18-2018, 05:46 PM
randeez's Avatar
randeez
randeez is offline
H-sport rear sway and camber arms are SOLD!
Old 03-22-2018, 06:45 PM
randeez's Avatar
randeez
randeez is offline
Info added to first post:
Clutch - the dark color is a coating applied to the surfaces, not even bedded in quite yet
Old 03-22-2018, 06:46 PM
randeez's Avatar
randeez
randeez is offline
Info on first post
Old 03-23-2018, 06:52 PM
Kyoungjr17's Avatar
Kyoungjr17
Kyoungjr17 is offline
Pmd
MiniJayhawk
04-13-2008 04:09 PM
d6-mcs
10-01-2005 08:52 AM
jcooper
Suspension
12-29-2003 12:36 PM
Electrc109
Cooper (non S)
09-19-2003 09:38 PM
Quick Reply: FS:: Hsport,Alta, Aquamist,HPFP
