Official MINI DRLs Fitted
Old Nov 29, 2016 | 09:48 PM
  #726
JustinGTP's Avatar
JustinGTP
Great info.
Do fog lights stay on with high beams with coding or not?
Old Nov 30, 2016 | 02:51 AM
  #727
cerenkov's Avatar
cerenkov
Originally Posted by JustinGTP
Great info.
With coding they do.
Old Nov 30, 2016 | 08:10 AM
  #728
JustinGTP's Avatar
JustinGTP
These led ones, right? I should have specified. Thanks!
Old Nov 30, 2016 | 08:57 AM
  #729
cerenkov's Avatar
cerenkov
Yes with the MINI LED halo style driving lights. Using NCS Expert change the following in the FRM:
FL_UND_NSW_NICHT_GLEICHZ
nicht_aktiv
Enables fronts fog lights and high beams at the same time
Old Dec 1, 2016 | 12:05 PM
  #730
JustinGTP's Avatar
JustinGTP
nicht_aktiv
Sweet! I already have the coding in place for flash to pass with fogs on and high beams with fogs on.
I ordered a set from UK for 400 cad shipped and import prepaid. That's 300 USD. Woot woot.
Old Dec 1, 2016 | 02:14 PM
  #731
JustinGTP's Avatar
JustinGTP
out of curiousity, has anyone else noticed the MINI DRL kit is slightly different than the new OEM LED fog option on the 15 lci countryman?
Old Dec 1, 2016 | 02:17 PM
  #732
yea the factory ones installed are different than the retrofit kit. The retrofit kit is brighter on the halo and a tad more blue/purple compared to the factory ones.
https://www.ecstuning.com/Search/SiteSearch/63122338554/
Old Mar 15, 2017 | 09:45 AM
  #733
Price dropped a bit on these from MINI.
Old Sep 23, 2017 | 12:14 PM
  #734
walk0080's Avatar
walk0080
Old Mar 22, 2018 | 02:09 AM
  #735
blackspider's Avatar
blackspider
Hello,
I have a R56 lci 2012 Cooper S, i want to fit these retrofit DRL but i don't have Auto Lights feature in my car. Can i still do it?
I have the 520 foglight option in my car though.
Help would be great :-)
Thanks.
Old Mar 22, 2018 | 04:49 AM
  #736
spiney's Avatar
spiney
Originally Posted by blackspider
Hello,
Thanks.
As long as you have the foglights that's enough. You have to disable daytime running lights in the car menu though, if the headlights are on with the standard wiring you just get the upper third of the DRL ring.
Old Mar 22, 2018 | 04:52 AM
  #737
blackspider
I don't have the option to disable or enable DRL in the car menu. Could't find it in the idrive like thing Mini has.
Old Mar 22, 2018 | 05:03 AM
  #738
spiney's Avatar
spiney
Unless you're in Canada it's in there.
Old Apr 11, 2018 | 08:50 AM
  #739
walk0080's Avatar
walk0080
Old Apr 18, 2018 | 11:03 PM
  #740
JustinGTP's Avatar
JustinGTP
It's not possible with this kit unfortunately. With the way it's wired into the car, the moment the lights are on it changes the rings to parking lights
Originally Posted by walk0080
Does anyone else have their car coded to keep the fender corner marker lights and taillights lit with the DRL LEDs on during the day
With everything setup, the DRL are on during the day (xenon are off), but all other exterior lights are off. In the past, before I removed/coded-out the Canadian region setting, the Xenon would be on for DRL along with my corner marker lights.
(I have bright LED lights in the fenders and they are visible during the daytime. I also like having the rear tailing LEDs lit during the day.)
Mini'mon
Aug 16, 2015 04:15 PM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
