2012 countryman all4 s engine noise
Help! just bought this car and the check engine light is on im concerned about the sound and wondering if it’s normal or not. Thanks in advance! |
That is because the car is on and running lol. Does anyone else hear anything?
If you have a CEL then you should buy a code reader or go to a place that will read the codes for you. Then post the codes here for people to help. |
What code reader do you recommend?
The Foxwell NT520 is my personal choice. It is a newer generation than the NT510/Schwaben tool that most recommend. I got mine off eBay for $135 shipped.
Codes from autozone
p0456 - evaporated emissions system very small leak p052b - coldstart intake A camshaft position timing retarded The person who had the car before me installed a new camshaft sensor but broke the bolt. ����*♀️It needs drilled out or I need a new valve cover. |
P0456 - evaporative emission system very small leak
P052B - cold start Intake (A) camshaft timing retarded the person who owned the car before me replaced the camshaft sensor but broke the bolt. ����*♀️ It needs drilled out now or I need a new valve cover. This could be causing the CEL, right? |
Sounds the exact same as my '12 CM S
I got 4 codes
3 were evaporative emission very small leak 1 was coldstart timing intake (a) camshaft timing retarded p0456 and p052b |
The evaporative codes could be as simple as your gas cap. Perhaps the p052b is causing the noise you're hearing. Where did you just buy the car from?
I bought the car from private party. No warranty or anything. Changed the oil and the CEL is off for now. I’m paranoid about the the timing chain. I may just change it so I can forget about it!
