How many failed HPFPs? Enough to investigate?
Old Jun 30, 2018 | 09:54 AM
  #26
Toaliosis's Avatar
Toaliosis
Angry
When you about to lose power/studder, do you hear a clicking noise coming from the engine compartment?
I've had the HPFP replaced 3 times in the 2012 Countryman S All4 and the coils replaced as well by the dealership under the extended warranty. Now, the car will still studder and produce a clicking noise, but not throw any codes. Typically this happens when the car is going up a slight grade, 3-4,000 RPM and 35 mph (don't quote me on these figures as I'm going from memory).
My concern is the car is showing the same symptoms, but not throwing codes and the extended warranty expires in a few months. Replaceing the HPFP seems to be pretty expensive, so thinking hard about selling the car...
JT
Old Jun 30, 2018 | 11:49 AM
  #27
MrGrumpy's Avatar
MrGrumpy
Originally Posted by AWD_Rally
I think I'm begining to see symptoms.
On cold start it'll be a rough/jerky idle, then be good for basically the rest of the day.
The MINI dealer near me said they basically wont replace it until it fails, or meets specific diagnostics of codes...
Is this true? Or should I try another dealer?
new spark plugs can solve this issue sometimes as well, could just be the plugs, are you getting any codes?
Old Jul 9, 2018 | 11:04 AM
  #28
y8s's Avatar
y8s
HPFP for my 3/2012 Countryman S has a factory warranty through 120,000 miles or until March of 2022.
You can call with the last 7 of your VIN to confirm that it's warrantied for the full 10yr/120k.
Mine typically throws codes when I'm off the gas and coasting in gear. It's incredibly repeatable. It never codes when accelerating.
Old Jul 10, 2018 | 08:55 AM
  #29
+1 ^^ call the dealer first to check.
If you are out of warranty, we just added some lower cost direct manufacture options. We have them for all the MINI Gen 2 HPFP now. R60 and R61 fitment also, just look at the years in the redlines. https://www.ecstuning.com/News/MINI_...el_Pump_22527/
Old Jul 17, 2018 | 11:38 AM
  #30
y8s's Avatar
y8s
5 days and a 6 year newer loaner and my car has its second replacement HPFP for zero monies out the door.
Old Jun 4, 2021 | 10:00 AM
  #31
y8s's Avatar
y8s
Few days ago I get this fun stuff again from Carly app:
002F7C Super knocking: injection shutdown
002BE9 Cylinder inection shutdown: pressure too low in high-pressure system
002C01 High-pressure fuel, plausibility: pressure to low
002F76 Super knocking cylinder 1: injection shutdown
Might be time to take this thing in for a third HPFP replacement. I'm just over 80k miles and about 9 years 3 months of age...
Old Jun 22, 2021 | 01:06 PM
  #32
y8s's Avatar
y8s
and new HPFP is installed and running smoothly...
Old Aug 25, 2021 | 10:46 AM
  #33
twilson's Avatar
twilson
I'm looking to buy a Mini Countryman. This forum has been great for my research. Thanks everyone! Curious to know how much these HPFP replacements typically cost (out of warranty)?
Old Aug 25, 2021 | 07:02 PM
  #34
mikey_t's Avatar
mikey_t
I believe it was anywhere from $850 - $1100 depending on where you go unless you're doing the work yourself which should bring the cost down to about $600
Old Dec 5, 2021 | 10:22 AM
  #35
stiksandstones's Avatar
stiksandstones
Is the HPFP the same as 'water pump' I read about on reddit? came with a black plastic continental but, later switched to Bosch? how can I tell?
Old Dec 6, 2021 | 07:17 AM
  #36
Nope, just a touchy design that likes to fail. I had my pump last over 118K now (Genuine MINI) and some genuine HPFP last 50K. I have not let my gas run low and that might have bought my HPFP some extra life as it did not let small particle get picked up by the pump and work past the filter.
Waterpump is plastic that went to metal. A quick look tells you.
Old Dec 6, 2021 | 05:47 PM
  #37
mikey_t's Avatar
mikey_t
As ESCTuning says.... I had mine replaced back in 2013 and learned my lesson about letting the fuel tank run low. I've never let it go below a quarter tank since then and I haven't replaced my HPFP again. The water pump also likes to fail just like the HPFP and no they're not the same.
brightside
Oct 4, 2018 12:31 PM
minicountry
Nov 16, 2015 01:07 PM
raleighminidude
Oct 5, 2015 07:03 AM
Z06C5R
Jun 8, 2014 02:56 PM
enronforme
May 12, 2014 12:12 PM
