R60 Blinking and then solid engine light
Mini is down right now and hopefully not for the count.
Engine was perfectly normal this morning, driving to work, until I started uphill and pressed on the accelerator.
Check engine light started blinking and then went solid. The car went into limp mode, shook pretty bad as I pulled over quickly.
I have no idea what is wrong (assuming it was misfiring for who knows what reason.)
It's at a shop so I hope they can scan the code to see what is wrong tomorrow.
Pretty bummed. Its a 2012 R60 S All4 with only 46K miles. It's stock and does not get driven hard.
Diagnosed as an ignition coil.... a $32 part from Rockauto.
I am having to pay 290 to have a shop do it - because I do not have a code reader.
For my F150, I have an SCT X4, IDS and Forscan. I can do anything and everything. With this MINI, I feel helpless given I do not have the basic tools needed.
Can anyone please recommend a good code reader? Also, is there software to read/write asbuilt data?
Thank you!
Thank you!
I have a generic wifi ELM OBD access point that plugs into the car, and I use the Carly app to read out the controllers. Works great for getting the Mini specific codes. If you get the "Official" Carly OBD dongle, you can get freeze frame data and live data streaming, if you care about that stuff. If you just want to read codes, then the generic one works fine.
You can also perform coding with the Carly app.
Coils and Plugs replaced
Replaced the coils and plugs, all is good in the mini hood! LOL! The problem is fixed and the countryman is running so much better. The plugs looked very worn and the coils showed their 40,000 miles.
The coils came with with a lifetime warranty!!! Plugs were limited lifetime... not 100% what that means... but I kept the receipt for both of them. Now all I have to do is clear the codes!
My question is, what is the factory recommended replacement for plugs and coils?
