R60 Coolant change DIY
05-10-2017, 06:10 PM
on
Coolant change DIY
Hey all!
About to embark on a coolant change this weekend and wanted to quickly double check that it's basically the same as any BMW: Drain radiator via some obvious plug, drain block via drain bolt, fill.
Anybody done one yet? Anything I should know?
Brandon
05-10-2017, 08:05 PM
Not.sure if there is a drain for the block but I could be wrong. Still learning about minis. But there should be a bleeder screw down by the thermostat to help get air out once you fill back up.
