R60 Programming Used Key FOB
Purchased a 2014 Countryman S with Comfort Access about 6 months back. Since it only came wth one key I figured I would just buy a used key online and then get it re-programmed. As of right now, i've purchased 2 keys (1 CA key and 1 non-CA key) from 2 different sources. I've been told by multiple independent key makers that you can't reprogram used keys, and then told by the dealer that THEY can't reprogram used keys.
So my question is:
1. Can used keys be programmed?
2. If not, then why are people (on this site) advertising used keys for sale that can be easily programmed?
So my question is:
mikey_t is correct. The remote control boards on the first generation, two and three button keys can be reprogrammed to a different car. Two button remotes require computer coding, three button remotes can be "paired" to the car with a series of button pushes. Beyond that, there is the blade which would need to be replaced and cut to your car and the EWS/Immobilizer chip, which would need to be created to allow the car to start. There are three distinct parts to a MINI remote key.
The best thing to do is just to save up some $$$ and get a key from MINI. Yes, it's expensive but it's the only real place to get a key for your MINI that will work properly.
If anybody is advertising that a used MINI key can be easily re-programmed they are lying. They just want your money; most keys hawked on eBay for example come with the disclaimer that you need to do the research to make sure the key can be re-programmed. It's how they get away with selling them and putting the responsibility on you for the programming. Perhaps it's easier with other makes of cars and they don't know any better.
What you aren't telling anyone here in the Countryman/Paceman forum is that you have a 1st generation key fob from a 2005 vehicle. We've already acknowledged that those keys can be reprogrammed. This thread is about the 2nd generation key fobs that cannot be reprogrammed.
