Interior/Exterior Driving Lights Installation
Hello all!
I'm interested in putting driving lights on my '16 CMS. I really can't afford the install cost though. Are these relatively easy to install and hook up? I'm not auto mechanically inclined at all but good at following instructions.
I'm thinking of purchasing the OEM set on Outmotoring.com.
Thanks guys and gals!
Lisa
Lisa
A bit of a challenge. I think there are some good youtubes on the process also.
These are the instructions that come with them. I love mine they are great for spotting deer along the road. The xenon's are focused on the road, but you also need to see what is going to jump out.
http://www.minimania.com/pdfile/R56_Rally_Lights.pdf
Driving lights install, then you will need the grille / rally light combo for your Countryman. The NEW LED version are out see below.
https://www.northamericanmotoring.co...hotos-116.html
You get the lights set # 1 , which come with the covers
Driving Lights Retrofit Kit - Black 63120417885
http://www.ecstuning.com/Search/SiteSearch/63120417885/
OR
Driving Lights Retrofit Kit - Chrome 63210420292
http://www.ecstuning.com/Search/SiteSearch/63210420292/
OR The NEW** LED version
#1 LED Driving Lights Retrofit Kit - Black 63122288982
http://www.ecstuning.com/Search/SiteSearch/63122288982/
OR
#1 LED Driving Lights Retrofit Kit - Chrome 63122288981
http://www.ecstuning.com/Search/SiteSearch/63122288981/
Then # 3 Trim with button 51452327908
http://www.ecstuning.com/Search/SiteSearch/51452327908/
Then you will have to select the grille you have: Which comes with the mounts.
-7/2011 Cooper S / SX / JCW 63132186306
http://www.ecstuning.com/Search/SiteSearch/63132186306/
OR
7/2011-7/2014 Cooper S / SX / JCW 63132241489
http://www.ecstuning.com/Search/SiteSearch/63132241489/
7/2014+
Cooper S / SX 63132360284
https://www.ecstuning.com/Search/SiteSearch/63132360284/
OR
For the Cooper People ( NON S ) ..
Cooper ( Non S ) Non chrome line -7/2014 63132186304
http://www.ecstuning.com/Search/SiteSearch/63132186304/
Cooper ( Non S ) Chrome Line -7/2104 63132186305
http://www.ecstuning.com/Search/SiteSearch/63132186305/
The covers can be purchased individually for needs or a change.
Cover Cap - Black - Priced Each 63120432836
http://www.ecstuning.com/Search/SiteSearch/63120432836/
OR
Cover Cap White - Priced Each 63120417672
http://www.ecstuning.com/Search/SiteSearch/63120417672/
If the glass ever breaks or gets damaged we have the glass part here, very few people even know this does exsist. 63220432342
http://www.ecstuning.com/News/MINI_R55_R56_R57_R58_R59_R60_R61_Rally_Light_Lense s_2007_2008_2009_2010_2011_2012_2013_2014/
OR
OR
OR
7/2014+
OR
OR
Driving lights install, then you will need the grille / rally light combo for your Countryman. The NEW LED version are not out yet like they are for the R56- R59.
OR
OR
7/2014+
OR
OR
OR
OR
7/2014+
OR
OR
Sorry the LED ones are out. Just did not update the thread ^^
Hello, if you have the halogen already installed, you will just need the light fixture kit,. Which come with a new harness, you cant get the NEW LED light fixtures by themselves , bit comes with the harness. You just pop the old fixtures off with the short wire harness plugs and pop the new ones in. You could ebay or keep the harness part.
Welcome.
Looks like you would just have to cut some holes in it for the brackets to get through.
All the stuff posted above is obviously the RIGHT way (OEM way) of doing it. The other way is to use whatever lights you want, mounted probably to those brackets (since they exist) and then you could power them independently and use a relay from an unused ACC circuit or even the parking lamps.
For the R60/ R61 the grille / brackets is a combo. No separate part number for just the brackets.
They fit, we just tested them.
63122360496
https://www.ecstuning.com/b-genuine-mini-parts/cover-cap-white-led-priced-each/63122360496/
63122360496
63122360496
63122360496
ECSTuning (11-06-2017)
63122288982 Black LED version are back in stock.
^ still in stock
Wohnson89
06-10-2020 04:53 AM
ryGuyMCS
10-20-2015 02:24 PM
squawSkiBum
10-02-2015 09:21 AM
