high RPM sounds like backfire
Recently my CM S feels like hesitation or backfire whenever I press heavily on the gas peddle (high RPM)
Any one have any idea, I was thinking of a bad plug or bad coil, no codes. The car is running Stage2 ….. normal driving everything is fine. Thanks |
Originally Posted by minicountrymanS
(Post 4463129)
Any one have any idea, I was thinking of a bad plug or bad coil, no codes. The car is running Stage2 ….. normal driving everything is fine. Thanks mQubed Motorsport Manic & RPM Power Tuning |
Great, thank you so much Mario, I will start with the plugs and then coils … the HPFP was replace under warranty a couple of years ago.
Thanks a million Patrick |
Just replaced the plugs with an old set I had kept, they solved the problem, will be ordering a new set.
Great forum thanks again Mario. |
(Post 4464403)
Great forum thanks again Mario. mQubed Motorsport Manic & RPM Power Tuning |
Glad to hear it’s resolved. Many times it won’t show a fault but will show a fault when plugged into a BMW diagnostic software like ISTA, etc.
Today's update, this morning I replaced the 4 coils (with OEM ones) and that finally corrected the backfires at high RPM.
The Ponies are back on my CM stage 2. |
