Wider tires
Wider tires
Hey Guys,
I’m looking for tires for my wife’s R60. Stock tires are 225/45/18. I want to go wider and 255/40/18 is about the closest to the OE size as I can get. The difference is 30mm witch is just a little over half an inch on each side. I don’t think there will be any clearance issues but wondering if anyone has done anything like this already.
Also, there are a lot of good tires in that size and I’m wondering what you all are running. The BF Goodrich G-Force Comp 2-AS and the General G-Max AS -05 were rated really well on Tire Rack. Also surprisingly the Sumitomo HTR AS P02 are cheap and also scored well and had decent reviews. I’m a little leery about the sumitomo’s though.
Thanks formyour feedback
Dom
Dom
From Tire Rack:
As you're shopping for winter wheels and tires, you'll likely come across the recommendation of going to a narrower tire. This is the exact opposite approach that you would take for summer traction, where wider is better. If you're likely to drive through deep snow this year, you'll want winter / snow tires and wheels in sizes that help put the laws of physics on your side.
The reason for this is that traction is achieved in winter by cutting through the ice and snow. With wider tread, you're more likely to start snow plowing or floating on top of the surface instead of pushing down and through. This floating will result in loss of traction sooner than with a thinner or narrower option. A good way to picture this is imagine a pizza cutter slicing through a pizza.
Another way to think about this is from the perspective of the contact patch. A tire's contact patch or "footprint" greatly influences its performance. On the same vehicle, the area of the contact patch essentially remains the same with different width tires. When the footprint gets narrower as it will with a narrower width tire, it has to get longer. And the mechanics of the longer footprint help with the longitudinal traction for acceleration and braking.
From Tire Rack:
I don't think 255s really fit. I think what you would want is 245/40/18....and even those might need aftermarket wheels or spacers to get them out a little.
good info: https://www.northamericanmotoring.co...ml#post4182850
Eduardo Ricardo IV (08-01-2020)
I think what you would want is 245/40/18. I don't think 255s really fit.
Dom
5mm is enough, but you need to see how that gap likely changes with suspension articulation. Typically it would increase with compression and maybe hit the tire on rebound.
This is why the aftermarket 40-45mm offset wheels are likely needed for such width. Worst case its a good excuse for new ones!. If you do, also get the lightest ones you can afford.
So I'll return these tires and just buy the stock size. Still going to be a hell of a better tire than the stock Duellers HP Sports. Sometime before these new ones need to be replaced I'll get wheel spacers. It'll be a funny test to see if the wife notices. LOL
Then in 2yrs or so when these new tires need to be replaced I'll have the wheel spacers and can play around more with wider tires options.
Dom
245 is about as wide as we can fit, without having a lot of negative camber. Width is nice, but if the tires dont heat up all the way, you'll never really see the full potential of the wider tires.
I think 245 is probably more than big enough for the power and size of our cars, 255 would be cool, I just think it would add rotational mass at that point and not totally benefit from the extra rubber.
I think 245 would be a perfect fit for our cars as a tuned car, I would definitely upgrade brake pads too.
I have 17x8.5" ET40 wheels that I'll be wrapping in 245/45/17 soon.
1RavingLunatic (01-06-2018)
wait- my oem tires are 205...... not 225......
with the low power output of the engine, rotating 255 or 245 wwould probably kill your mpg
i was thinking of bumping to 215 just to get less highway road steer, but i couldnt see 245 for any reason- even for snow. the footprint benefit would be nulified by the lack of power ability to turn that 245 through snow.
Even in the summer time, a stock S wouldn't see a benefit at all. The heavy OE wheels with bigger tires will definitely add rotational weight, which is weight we don't want. I think 225 tire is plenty with a stock (37mm) or JCW (39mm) turbo.
My tire & wheel setup, for example, will be dropping roughly #40 of rotational mass. 17x8.5" with 245/45-17 tires. I also have 100+ hp over stock. I also have a clutch/flyhweel installed that dropped #20.
No rubbing at full lock. The two pics that the wheel is turned, is full lock both directions.I could fit 45 series tire, but with less than an inch of clearance at full lock with the 40 series tire, it’s to close for my comfort. At full lock and a large bump, a 45 series would rub...nut much just a kiss. But if it rubs, it does not truely fit.
No change from stock in camber on front or rear. No spacers.
