R60 Time for a Wax Job
i use to do body work and detail cars.. i would mask all the moldings off with masking tape,, it will save u time and headache in the end
Stuff I use is from Griot's Garage. They've got everything you can think of including some things you'd never have thought of.
+1 on clay bar before waxing. It's easy to do and doesn't take very long. Blue painter's tape works fine for masking off the black trim. You don't want wax on that stuff. If you have vinyl stripes wax is OK but don't ever polish over them. For absolutely the best finish on the black trim is Black Wow from Richard Lin at showcardetailing.com, only thing I don't get from Griot's. You can get it from a few other places now too. Right after application it will gather a bit of dust but after the next washing they're good to go.
well that depends on the level of finish you want or expect. for some people a quick wipe on/off a couple times a year is good enough for them, other people want to see the richness and glow a well treated paint gives. either way, it's entirely up to you.
after you feel and see the difference between a good clay, polish and seal job compared to an over the counter quick wax it'd be hard to take the step back.
In my opinion, taping off the black trim is overkill and is the old way of doing things. No need to do that with different products.
Here's my suggestion for waxing and protecting your car's paint without much trouble:
1. Wash it well
2. Apply Prima Hydro Max Super Spray Polymer. It is a paint sealant (like a wax but ) that will last several months at least. Your paint will be protected and will have a great shine. It's just a spray on/wipe off application that will be done in less than 20 minutes. No buffing, no curing. Just spray it on and wipe it off according to the directions.
3. About every month or so, use Prima Banana Gloss. Again, it's just a quick wipe on/wipe off process that can be done in the sun/shade or wherever and only takes a few minutes. It looks fantastic. It also helps to conceal paint swirls.
4. Finally, after each wash when you are drying the car, spritz a few sprays of Prima Hydro onto the car as you dry. It's a "wax as you dry" spray that leaves a great shine and added protection.
1. Wash it well
If you JUST want to wax the car and not get into all the other considerations, I really find Optimum Spray Wax to be the easiest thing to apply and it lasts a reasonably long time.
http://www.optimumcarcare.com/owax.php
to amazon!
to amazon!
Those are good, I'm a Griot's user but most others do quite well. Quick detailers are just that for taking care of those dusty days between washings. They do put on a great shine. Quality of microfiber is important too.
on
Nanoskin Autoscrub
http://www.autogeek.net/nanoskin-clay-towel.html
it works same as clay bar but its a lot easier to use. after that put on a wax or sealant
