R60 Alarm keeps going off after air filter change
Does the MINI (2012 R60) know that an aftermarket air filter (K&M) has been installed? Call me crazy, but when I put the K&N filter in and set my alarm, it always goes off after 30 seconds.
I checked all connections, sensors, ensured hood was properly closed, checked the hood-closed switch, removed and reinstalled the AM filter, and still had the issue.
Put the stock filter back in, and everything returned to normal.
Put K&N filter back in, and the problem returned.
Repeated that three times to ensure I wasn't crazy, and the pattern repeats.
Again, am I crazy, or am I amazingly knocking over a sensor when putting the K&N filter in, and putting it back in its place when putting the stock filter in? Doesn't seem to be a sensor within the air filter housing itself, so I have no idea how something like that would work, but this is driving me nuts as the alarm only malfunctions with the K&N filter in.
Okay since no one on this forum gives you advice anymore, first re-install the stock filter. Then drive around a mile or two. Head back home or wherever and install the K&N filter. Drive around a bit. If the same issue occurs, could be because your K&N filter is over oiled up. Just so you know there is a dry performance filter by AFe. I plan to head that direction next time so I don't have to mess with the mass air flow sensor.
Good luck.
Good luck.
Okay since no one on this forum gives you advice anymore, first re-install the stock filter. Then drive around a mile or two. Head back home or wherever and install the K&N filter. Drive around a bit. If the same issue occurs, could be because your K&N filter is over oiled up. Just so you know there is a dry performance filter by AFe. I plan to head that direction next time so I don't have to mess with the mass air flow sensor. Good luck.
Let's assume it's an oily filter. The sensors would know this as soon as I set the alarm, without ever having driven it with the K&N filter? And it would trip the alarm instead of throwing on a warning light?
Just to be clear, the car was never turned on nor driven between filter swaps. I guess it's possible the sensing takes place when the hood switch is activated upon opening and/or closing.
Still, very strange behavior over an air filter, right?
Not sure an oily filter could set off An anti theft alarm....lol...it might set a engine trouble code/yellow light...
Had to check to make sure it was not April 1st....
My guess...
Do the change then drive...
Bet having the hood open then not driving set off some kind of timer...activating the alarm...
My guess...
Not sure an oily filter could set off An anti theft alarm....lol...it might set a engine trouble code/yellow light... Had to check to make sure it was not April 1st.... My guess... Do the change then drive... Bet having the hood open then not driving set off some kind of timer...activating the alarm...
Maybe the op could try some holy water or burn some insense.... Drive out the evil spirits?!
This is a odd one!!
One thought....
Warrenty expiration/voiding monitoring system is kicking in?! Jk.
Thanks for the response. Let's assume it's an oily filter. The sensors would know this as soon as I set the alarm, without ever having driven it with the K&N filter? And it would trip the alarm instead of throwing on a warning light? Just to be clear, the car was never turned on nor driven between filter swaps. I guess it's possible the sensing takes place when the hood switch is activated upon opening and/or closing. Still, very strange behavior over an air filter, right?
Vendor
silence2-38554
98
09-21-2016 02:52 PM
polotska
08-23-2015 09:10 AM
