R60 Trunk Liner (that goes into the under trunk)
Hey there:
I have a 2011 countryman. Anyone know of a trunk liner (for the trunk part that go in the underwell under the load floor flap)?
I think the weathertech goes on top of the movable load floor piece (hope I'm explaining this correctly).
Thanks,
DG
Thanks,
DG
Something like this?
http://new.minimania.com/part/NMA760...--Cooper-And-S
Not sure if the floor folds flat over it though!!??
EDIT!: Never mind. . .I see now that you wanter a liner not an organizer!!! DOH!
All the ones I've seen go on top, which is stupid. Let me know if you find anything. I really want one for ski season, since boots fit under there perfectly. MINI only makes one for underneath for the Clubman, but only makes the top one for the Countryman. It's aggravating.
Found this one: http://www.bootsliners.co.uk/MINI-CO...OOT-LINER.html. Don't know how well it fits.
Anyone know if there is a different lower floor dimension for flat load vs standard? Seems like they should be the same.
I did the same, except I cut a scrap piece of diamond garage floor covering to fit. Of all the places to install the patented dirt-and-hair-magnet material that MINI calls "carpeting," this compartment makes the least sense.
Did you get this one?
Did you end up buying the one that you linked to below? It looks exactly like what I want, but I wonder how it fits. Can you post a picture if you got it? Thanks so much!
Anyone know if there is a different lower floor dimension for flat load vs standard? Seems like they should be the same.[/QUOTE]
