R60 Fog lights as DRL
@icuc,
Probably best to pursue the FRM module changes in the R60 Modifications Electrical forum. Look in the Countryman-Specific Coding - R60 thread. Check out my NCS Expert directed question HERE.
HTH,
HTH,
Should have stated "anything can be done", however, it won't be a dealer programming and will likely require you to re-wire the lights and maybe add your own switch. Fog lights do not work without at least parking lights on. They will not work with only DRLs. This is pretty standard in any car with fogs and I believe is a law.
@icuc,
HTH,
HTH,
I tried as you said but city light didn't turn on as DRL :(
This has been done (using the city lights as DRLs) without wiring using NCS Expert on a 2008 R56. Since the R60 uses much of the software and has many of the same NCS Expert settings as the R56, this may be possible on a 2011-12 R60. Not sure that the actual fogs can be used, but I see the R60 settings for the city lights (SML lights).
Indeed! He did state fog lights which, to my knowledge, have never been linked to the DRL via settings changes. There may be a shot at the city lights though, albeit with more NCS research on "DRL", "TFL" and "SML" in the trace files.
More than likely you have a law against running fogs unless there is fog. However, nobody follows the laws here in the USA anyway and they are rarely enforced. In other countries, Germany for instance, you wouldn't make it around the block without getting a ticket.
Just remember, just because others are doing it doesn't make it legal.
09-28-2021 01:16 PM
08-21-2015 12:58 PM
08-21-2015 12:58 PM
08-21-2015 12:50 PM
08-19-2015 12:51 PM
