R60 :: Countryman Talk (2010-2015) R60 Cooper and Cooper S hatchback discussion NOT REPAIR RELATED Discussions.
Sponsored by: DashLynx
R60 Going install a trailer hitch on the R60 to do a U-Haul trailer, bad idea?
Old 04-17-2012, 06:58 PM
darkus's Avatar
darkus
darkus is offline
I plan on installing a hitch thats available from minimania, and then hopefully hook it up to the smallest U-haul trailer availalbe (http://www.uhaul.com/Reservations/Eq....aspx?model=UV). The weight limits are definitely a bit close, but i'm hoping I can get away with it.
What do you guys think, is this a bad idea and just too much weight for my poor countryman? (she is an S...)
Thanks!
Old 04-17-2012, 07:06 PM
donaldq's Avatar
donaldq
donaldq is offline
Well, that hitch can only tow up to 1000lbs and the u-haul trailer is already 850lbs empty. So that means you can have only 150lbs load on the trailer, besides you don't want to reach the maximum limit on your countryman, do you?
Old 04-17-2012, 07:16 PM
Mojito's Avatar
Mojito
Mojito is offline
Do you plan on using the hitch for more than that? I'd borrow someone else's suv or rent a truck if you don't plan on using it often
Old 04-18-2012, 03:18 AM
MyroMini's Avatar
MyroMini
MyroMini is offline
Or go with MiniDoMore hitch for the Countryman, it's rated at 2000lbs
http://www.minidomore.com/mini_coope...iler_hitch.php
Old 04-18-2012, 05:26 AM
ljmattox's Avatar
ljmattox
ljmattox is offline
Given that you have a Class I hitch with 2,000 lbs towing capacity, you'll likely be ok:
My long-suffering Miata...Class I hitch, towed UHaul trailers *far* too many times. 1.8l, 133hp.
Old 04-18-2012, 06:08 AM
bmwr606's Avatar
bmwr606
bmwr606 is offline
here is a class II hitch for your R60
http://minifini.com/ShopDetail.aspx?id=68
"[FONT=Arial][FONT=Arial]The new Country-Link for the Mini Countryman is rated better than Class II (3,500 lbs towing / 300 lbs tongue weight)[/FONT][/FONT]"
scott
Old 04-18-2012, 07:50 AM
FredoinSF's Avatar
FredoinSF
FredoinSF is offline
Off topic, but I love the Miata.
Our first gen is one of the cars I would keep in my "I wish I had never sold that car garage" as it was in great shape and was unbelievable fun. Tough little cookie too!
Back to regular MINI programming.
Old 04-18-2012, 08:03 AM
threar's Avatar
threar
threar is offline
I've got the MiniDoMore hitch, picked it because it's rated higher. I've not tried to tow anything overly large, so I can't make any recommendations there.
Old 04-18-2012, 09:53 AM
eggmole's Avatar
eggmole
eggmole is offline
I have been looking into this and it looks like the Minifini will hold the most at 300lbs tounge weight and 3500lbs towing. they all seem to have a class I hitch(1 1/4"), but you can get adaptors.
I just want to be able to trailer my motorcycle and possibly another with my MINI to the dragon and other twisties, better when there are more riders. trying to knock out 2 birds with 1 stone.
Old 04-18-2012, 10:17 AM
Jimbo's Avatar
Jimbo
Jimbo is offline
Just got my MINIFINI Country Link 2 hitch currently making arrangments to have it installed, I'll be sure to post pics of the installation !
Old 04-19-2012, 10:53 AM
MINItitan's Avatar
MINItitan
MINItitan is offline
Can't tell you how many times I've said that same thing. Even after I bought the second gen miata....
Old 04-21-2012, 10:54 PM
KiwiRob's Avatar
KiwiRob
KiwiRob is offline
3500lbs is more than double the Countrymans maximum braked tow weight of 1650lbs.
Old 04-22-2012, 12:48 AM
shark715's Avatar
shark715
shark715 is offline
If you have a manual trans, given the clutch issues with this car I would think the last thing you would want to try is towing a trailer.
Old 04-22-2012, 03:55 PM
pyrrhusmj's Avatar
pyrrhusmj
pyrrhusmj is offline
I can only speak to my cabrio, but I towed quite a bit with it and used a cargo buddy with it. I have the minidomore hitch and experienced zero problems hauling the smallest open trailer Uhaul offers with about 500 pounds or so in it. Stayed well under the weight limit. I also have towed a few sport trailers, those are a piece of cake. So I would assume the Countryman being heavier would need a smaller load to still perform ok. It all depends on what you really plan to tow inside of the trailer.......
Old 04-23-2012, 02:44 PM
Shoe Coupe's Avatar
Shoe Coupe
Shoe Coupe is offline
can you elaborate on the clutch issues?
Old 04-23-2012, 03:05 PM
bmwr606's Avatar
bmwr606
bmwr606 is offline
i have towed a 15,000 pound gross weight trailer for 10 of thousands of miles behind my 1997 gmc sonoma 4.3 5-speed 4x4.
it is "rated" for 4,500 pounds
it now has 287,000 miles on the original clutch and throw-out bearing
if you know how to drive a manual transmission properly, towing will not stress the clutch ... i present my truck as evidense
i plan on a hitch for my countryman s all4 and have zero concerns for the clutch
scott
Old 04-23-2012, 03:10 PM
shark715's Avatar
shark715
shark715 is offline
See the thread in the CM section entitled "Smelly Clutch"
Old 04-23-2012, 03:15 PM
shark715's Avatar
shark715
shark715 is offline
scott
Scott, I've done a lot of heavy towing myself with other trucks...what you are saying is impressive to say the least. What were you towing? What kind of hitch did you use, and what was the tongue weight?
Old 04-23-2012, 03:34 PM
bmwr606's Avatar
bmwr606
bmwr606 is offline
towing a retired nascar sprint cup car and tools and all the support stuff that was raced in the midwest in gp2 "run what you brung" class
i would relocate the trailer for the owner/driver
only saw it race once
it was a 3 axel trailer, i have a load equalizing hitch, tongue weight was usually around 500 pounds on a scale before attaching the trailer to the hitch
first time i towed it the tongue weight was 750 pounds....my truck was not happy
amazingly, my gas mileage only took about a 20% hit, from 20 to 16 mpg
the trailer brakes failed once ... the stopping distance was about the same as a nimitz class aircraft carrier
scott
Old 04-28-2012, 08:57 PM
Jimbo's Avatar
Jimbo
Jimbo is offline
MINIFINI install on Base CM
Here are some pic of my MINI FINI install very neat and almost un noticeable when not in use
Attached Thumbnails Going install a trailer hitch on the R60 to do a U-Haul trailer, bad idea?-p4282005.jpg   Going install a trailer hitch on the R60 to do a U-Haul trailer, bad idea?-p4282010.jpg   Going install a trailer hitch on the R60 to do a U-Haul trailer, bad idea?-p4282012.jpg
Old 05-20-2012, 11:44 AM
binitraveller's Avatar
binitraveller
binitraveller is offline
how hard was the install? looks like you have to cut out some of rear plastic?
thanks
Old 05-20-2012, 01:05 PM
Jimbo's Avatar
Jimbo
Jimbo is offline
Yes some of the black plastic on the underside of the bumper cover had to be cut but it was very minimal and most people don't even see it.
I see you drive and ALL4 S, on yours even less cutting is required as the receiver lines up with the grill work on your lower bumper cover and only a hole the size of the receiver has to be cut and your receiver cover plugs the opening when not in use. See photo below.
Old 05-20-2012, 03:38 PM
boomerwang's Avatar
boomerwang
boomerwang is offline
Has anyone bought a hitch from these guys? Theirs look pretty slick too
http://coopercrap.com/countryman-hitch/
Old 05-20-2012, 05:16 PM
Jimbo's Avatar
Jimbo
Jimbo is offline
There are several like that that use the existing bike rack connectors,but there is just much going on to leave it on for a short disconnect unlike a conventional hitch where you just have to pull a pin and it's gone!
Old 05-20-2012, 09:21 PM
pyrrhusmj's Avatar
pyrrhusmj
Not going to disagree entirely, but personally I like the idea of zero modification to the car. One of the things I loved about my MINIDOMORE hitch on non-CM's was the lack of needing to cut plastic. I am thinking I will do very little to physically modify my Countryman (famous last words).
Quick Reply: R60 Going install a trailer hitch on the R60 to do a U-Haul trailer, bad idea?
