Drivetrain Who has the BMS tune?
Old Feb 4, 2014 | 06:29 AM
  #101
Nmagnum7's Avatar
Nmagnum7
I didn't put it to "sleep" when I put it on. I have a alta intake and now this tune. Runs fine. No issues.
Old Feb 4, 2014 | 10:35 AM
  #102
minibluez's Avatar
minibluez
Originally Posted by aleclee
I can't imagine a bigger bang for the buck when it comes to performance mods. It's relatively cheap, easy to install, and 100% reversible. What's not to like?
Well summarized!!
Old Feb 4, 2014 | 07:26 PM
  #103
yesti's Avatar
yesti
Lucky you dodged the CEL by not following installation instructions
Old Feb 6, 2014 | 04:18 AM
  #104
Nmagnum7's Avatar
Nmagnum7
http://burgertuning.com/instructions/mini_jbplus.pdf
Where's it say to disconnect the battery. I must have missed it. There is no current running thru the mass air flow sensor if the vehicle is not on or in acc position.
Old Feb 6, 2014 | 04:31 AM
  #105
cerenkov's Avatar
cerenkov
http://burgertuning.com/instructions/mini_jbplus.pdf Where's it say to disconnect the battery. I must have missed it. There is no current running thru the mass air flow sensor if the vehicle is not on or in acc position.
You don't have to disconnect the battery. Just open the hood, lock the doors and let the computers go into sleep mode (takes about 15 min). Some computers are still active for a while after the car is turned off.
Old Feb 6, 2014 | 04:48 AM
  #106
dpike's Avatar
dpike
had this code pop..
P0171 - Powertrain
System too Lean (Bank 1)
using 93 oct. should i dial the JB+ down to like the 10 o'clock position ?
Old Feb 6, 2014 | 08:56 AM
  #107
yesti's Avatar
yesti
I didn't say to disconnect the battery but Step 1 is to sleep the car for at least 5 mins. However, I did have to disconnect the battery for some stereo installation-izing and reset some fuel trims so if that happens "don't floor the car for ~50 miles" is good advice.
Old Feb 10, 2014 | 09:28 AM
  #108
ayk07's Avatar
ayk07
just installed mine, i have the vip intake so i was confused at first, i am a dummy was looking for the maf sensor at the same spot but vip intake moves the spot up higher
Old Feb 10, 2014 | 10:01 AM
  #109
xenor's Avatar
xenor
ayk07, I ended up putting a carefully placed zip tie to prevent the box from bouncing around too much....did you do anything like this? I have the VIP intake also.
Old Feb 10, 2014 | 10:54 AM
  #110
ayk07's Avatar
ayk07
no but i might now that i think about it
Old Feb 10, 2014 | 01:46 PM
  #111
ke3ee's Avatar
ke3ee
I've had my BMS installed now for 10k. My ALL4S runs great, never an issue. I run 93 octane brand name fuel and the selector has not been touched. I have noticed for the last 1500 miles that my mileage is down a bit. I live in Pa so we are on winter gas mixture. I hit 30k this week so I changed my plugs today. The originals showed a rich mixture. I installed a set of factory Beru's and ran Seafoam cleaner thru the intake tube so it would go thru the Turbo and the intake valves to clean things up.
She idles a bit smoother now. As a side note I don't think There are any true CAI's for the Countryman that take in fresh outside cold air better than the stock system with a high flow filter. Its 20 degrees outside and that's enough for me for the day.
Old Feb 10, 2014 | 03:28 PM
  #112
boogernator's Avatar
boogernator
If I'm using 91 octane brand name petrol, do I need to dial it down from the stock 12 position?
Old Feb 10, 2014 | 05:14 PM
  #113
chrunck's Avatar
chrunck
I ran mine for a few thousand miles on the stock setting with no issues but dialed it down to 11 after awhile to play it safe. We only get 91 here in NM. I don't know if the 10% ethanol in the winter is better or worse for detonation.
Old Feb 10, 2014 | 06:32 PM
  #114
boogernator
Ok, cool. I'll probably do the same just to be safe. Thanks for the tip!
Old Feb 18, 2014 | 11:02 AM
  #115
dpike's Avatar
dpike
interesting...
i'm the only one so far who threw an engine lean code using the JB+ ?
Old Feb 18, 2014 | 05:23 PM
  #116
jackbt's Avatar
jackbt
Originally Posted by dpike
interesting...
That's interesting that you leaned out.
I've run 40/60 e85/91 at 80% and my afr was down in the 10.5:1. With reg gas (91) at 60% my afr was at 12.8-13:1 ....not saying 60% with (91) safe to do.
What year is your car?
What RPM did it happen?
which intake do you have installed?
Old Feb 18, 2014 | 05:35 PM
  #117
cerenkov's Avatar
cerenkov
Originally Posted by jackbt
That's interesting that you leaned out...I've run 40/60 e85/91 at 80% and my car leaned out but never threw a code. My afr was down in the 10.5:1 and no code. ...not saying this is safe to do...
Isn't 10.5:1 on the rich side?
Old Feb 18, 2014 | 06:02 PM
  #118
jackbt's Avatar
jackbt
Didn't explain myself well.
Yes 10.5:1 is rich, Iv'e been told, you want to be around 12.5:1 with these engines...
Every time Iv'e used E85 mixture, the car runs richer under load. With regular gas (91) I'm around 12.8:1.
Old Feb 18, 2014 | 10:36 PM
  #119
RobMuntean's Avatar
RobMuntean
Normal driving I see 13.2-14.0 but under hard acceleration I see 12.3.
Old Feb 19, 2014 | 04:54 AM
  #120
dpike's Avatar
dpike
it's a 2012 and i didn't see when the light popped on, no custom intake but using an afe dry filter. contacting burger they said this was common for the n18 to pop lean codes and i should buy the can tool to clear them... i don't think so. i'll have my dealer clear the code next time i'm up there, dial down the JB+ a bit and try it again...
Old Feb 19, 2014 | 12:45 PM
  #121
jackbt's Avatar
jackbt
Yes, Terry has told me the same thing as well about the N18 engine. We have the tune on 3 of our cars and one on a friends car with no problems... The cars we own are 2013/14. The reason I asked about the filter... Iv'e seen CAI throw lean at Idle codes. This specially happens when you are coasting downhill in neutral.
I'm sure you have a Driod or and Apple phone. Purchase a bluetooth OBD tool from Amazon for $12 and download an app for your phone ($5-$10). Torque Pro for Driod and DashCommand for Iphone and monitor your car. You can also clear the CEL every time it pops up.
Hope this helps! Good luck!
Old Feb 20, 2014 | 10:01 AM
  #122
dpike's Avatar
dpike
i had no idea torque pro could clear codes. it's where i pulled the lean code to begin with. thankyou for letting me know
Old Feb 20, 2014 | 10:09 AM
  #123
jackbt's Avatar
jackbt
Yep after you review the code in the "fault log manager" click on phone "menu" button and it's the first option "Clear faults on ECU"
Old Feb 21, 2014 | 04:40 AM
  #124
dpike's Avatar
dpike
worked like a charm !
thanks again.
Old Feb 21, 2014 | 06:29 AM
  #125
Nmagnum7's Avatar
Nmagnum7
Which Bluetooth obd plug in off amazon do you have? I can't seem to find many compatible with apple
