Drivetrain Intercooler Installation Pics
Old 03-23-2013, 01:44 PM
chrunck's Avatar
chrunck
chrunck is offline
I installed the Helix intercooler on my R60 last weekend and wanted to share some installation pics. I didn't take enough pictures for a full how-to, but these may be useful for anyone else installing one.
My order of operations:
1. Jack up car and remove front wheels. This isn't completely necessary, but it does make it easier to work.
2. Remove front grille. There are 4 10mm bolts on top, then pull bottom edge towards you to release. You can also remove the headlights to make it easier by removing 4 10mm bolts on each one.
3. Remove front bumper apron. This is pain in the *** the first time you do it, but it's not so bad once you get the hang of it. Open the cap inside the wheel well and disconnect fog lights, turn signal, and side reflector. Remove 2 torx screws underneath as well as 3 plastic rivets. Pop out the center pieces of the rivets on the underside of the arch trim, along with 1 8mm screw. Release the white rivet on the inside of the arch trim to pull it away from the car. You don't need to remove then entire arch, but you do need it to be free up to the halfway point so you can pull it away from the car. Underneath you'll find 1 torx screw on each side of the car. Once those are out, remove the 2 torx screws on the upper front of the apron and it should come free. This is the most time-intensive step, and it gets easier after this.
4. Remove the air ducts for the brakes. Do not remove the 4 8mm screws inside the wheel well--it won't do any good. They just pull forward off the car. Here is a pic--notice the two plugs that hold them in place.
5. There are 2 long plastic pieces on either side of the radiator that need to be removed. Make sure you unclip the temperature sensor from the passenger side one. They look like this:
When you're taking them off, you have to pull forward to clear these square cutouts. Feeling with your hand, it will feel like they are bolts, but they aren't. They just slide forward and then off.
6. Now remove the old intercooler. On the driver side, take a flathead screwdriver and insert vertically from below to loosen the hose clamp. It's easy once you find the right hole. On the passenger side, you have to angle in from behind, but this one is also fairly easy to access. After the hose clamps are loosened, just pull the intercooler forward until it comes free.
Here is the old vs the new:
7. While you have the intercooler and bumper off, it's generally recommended to do something about the muffler on the hot side (driver side) boost tube. The muffler is restrictive to airflow and you're generally better off without it. You have 2 options: replace the entire tube (NM sells one), or replace the muffler with a store-bought piece or make your own (there's a good thread here if you want to make your own).
Holding the muffler on is a T25 torx screw that's a major pain to get to because of the various hoses, but it can be done with enough perseverance. I used a torx screwdriver and it wasn't too bad. Whether you're replacing the entire tube or just the muffler, you need to remove this screw, loosen the hose clamp on the turbo and remove the entire tube by dropping out the bottoms side of the car.
In the thread above on removing the muffler, I read about this pre-intercooler cooling pipe which is basically a small intercooler for your intercooler. It's only $40, so I went with it. I doubt it can really cool all that much in the 9" or so of its length, but it can't hurt. Here's a couple pics of it in place of the muffler:
8. At this point, just reassemble in reverse. It's a lot quicker putting it back together than taking it apart. Here's the intercooler installed:
Underside view of the hot side boost tube:
Bumper apron back on and everything back together (except the wheels):
IMPORTANT NOTE: I highly recommend starting your car after installing the new intercooler and reconnecting all the tubes before putting the bumper back on. Should there be a loose connection somewhere, you don't want to have to disassemble everything all over again.
All in all, it took me about 4 hours, though that included a trip to the hardware store to buy a couple of hose clamps. If you buy the pre-intercooler pipe, make sure you pick up a couple of hose clamps that are 2.25" diameter.
Hopefully that is somewhat clear. I should have taken more pictures, but I didn't think about it until I had the bumper off. Let me know if you have any questions.
The following 4 users liked this post by chrunck:
aabcds (06-13-2019), anew742 (05-11-2019), OSilvera (09-16-2019), SunBird (11-18-2019)
Old 03-23-2013, 01:49 PM
Braminator's Avatar
Braminator
Braminator is offline
Great job on the write up. Let us know how it performs.
Old 03-23-2013, 02:23 PM
TonyCheckraise's Avatar
TonyCheckraise
TonyCheckraise is offline
That muffler replacement pipe sounds like a good idea, way cheaper than most pipes you see being sold as well.
Theoretically, as long as the air around the outside of the pipe is cooler (less hot?) than the air inside, it will definitely dissipate heat. Any temperature drop there, even if it's small, is a help!
Old 03-24-2013, 09:16 AM
Hujan's Avatar
Hujan
Hujan is offline
Looks good! Great writeup and good photos. Thanks for putting this together.
Old 10-27-2014, 04:52 PM
AWD_Rally's Avatar
AWD_Rally
AWD_Rally is offline
Moderator
good info!
Old 03-07-2015, 08:38 PM
miniwpbear's Avatar
miniwpbear
miniwpbear is offline
Thanks for the detailed write up. I was changing the boost tube and putting a M7 on but I was having problems getting the muffler tube out. The T25 Torx socket was indeed correct size....and a HUGE PITA to get out!
Old 04-15-2015, 07:55 PM
kohlersc's Avatar
kohlersc
kohlersc is offline
Did the hose clamps on the muffler not transfer over to the replacement cooler section? I'm thinking of taking the muffler out regardless of putting in a new intercooler. They look the same size...but it sounds like they arent?
Old 04-22-2015, 07:33 AM
miniwpbear's Avatar
miniwpbear
The M7 was a full replacement not just the muffler section like I have seen NM and VIP make.
Old 04-22-2015, 08:50 AM
PelicanParts.com's Avatar
PelicanParts.com
PelicanParts.com is online now
Vendor
Great write up and pictures! Looks good.
-Luccia
888.280.7799 | 6am - 5pm PST
Old 05-09-2015, 06:31 AM
chrunck's Avatar
chrunck
chrunck is offline
The hose clamps on the muffler weren't the reusable kind unfortunately. I had to make a quick trip to the hardware store.
Old 08-09-2015, 08:08 PM
bleonard1401's Avatar
bleonard1401
bleonard1401 is offline
Copied your setup today. Thanks for the step by step directions! It was still a huge PIA, but at least there were no surprises and last minute runs to the hardware store😀
Old 09-10-2015, 03:15 PM
HJCPmeek's Avatar
HJCPmeek
HJCPmeek is offline
I ordered my Helix IC and it shipped on Tuesday... Can't wait and I already have the M7 pipe installed. I'll post pics when I do the install - Thanks for the write up!
Old 09-21-2018, 08:39 AM
rotaryferreira's Avatar
rotaryferreira
rotaryferreira is offline
These are the kinds of posts i live for
OSilvera (09-17-2019)
Old 12-30-2018, 03:09 PM
Bayville Mini's Avatar
Bayville Mini
Bayville Mini is offline
Is a tune necessary after this mod?
Old 01-01-2019, 09:10 AM
AWD_Rally's Avatar
AWD_Rally
Moderator
No.
Old 04-08-2019, 10:33 AM
weaverpsu's Avatar
weaverpsu
weaverpsu is offline
Intercooler install
I watched the Helix video and they don't show the removal of brake ducts or those large plastic pieces. I'm guessing we have to on the Countryman? I also don't see the point of removing the wheels or headlights. Helix doesn't touch headlights but they do take off the wheels. Is this just for extra room? I ask because I bought car ramps for the downpipe install and planned on using them for this job as well because I don't have a jack or stands. Thanks!
Old 04-10-2019, 02:49 PM
weaverpsu's Avatar
weaverpsu
Finished
It becomes obvious the brake ducts and other 2 plastic pieces need to be removed when working on car. I would have loved the extra room and now see why someone would remove wheels. Headlights didn't need to come off.
Old 07-27-2019, 06:13 AM
Jeremy A Gruver's Avatar
Jeremy A Gruver
Jeremy A Gruver is offline
Thank you!
I keep learning more and more as I read on and on these threads this is wonderful!
Old 08-10-2019, 09:30 AM
Svampfest's Avatar
Svampfest
Svampfest is offline
Does this modification has any drawbacks compared to replacing whole tube (1 piece) ?
Old 08-10-2019, 12:26 PM
AWD_Rally's Avatar
AWD_Rally
Moderator
The benefit of replacing the pipe this way is that you'll save money. A 1 foot aluminum pipe is like $10 or something.
I personally just used a regular 2" aluminum straight pipe. Just measure and cut with a handsaw.
Originally Posted by Svampfest
Does this modification has and drawbacks compared to replacing whole tube (1 piece) ?
Svampfest (08-10-2019)
Old 10-03-2019, 04:34 AM
OSilvera's Avatar
OSilvera
OSilvera is offline
Just started my Helix Intercooler install last night.
Had some time to spare in the evening. I figured I'd do 30 minutes worth of work last night to save on some of the job this morning.
With the car on the ground
I removed the 4-10mm screws along the top of the front grill assembly and removed that.
On each side of the car I....
removed the 8mm screw in the fender well and then popped out the lower tab insert ( reusable press rivet/trim thingy) under the 8mm screw and removed 3 of the plastic rivets above the 8mm screw along the arch of the wheel well.
Pulled the black fender trim away from the car and carefully removed the bulb holder and bulb from the side marker.
Removed the 1 Silver Torx 20 side bolt.
then on the front of the car removed the 2 silver Torx 20 bolts on the top of the bumper cover. on either side of the radiator. Basically the two lower edges of where the grill would be.
At this point the bumper cover was loose, I pulled the top of it away from the car about 10" and saw that I could now access the connector on the lower DRL, disconnected those carefully.
I saw that the bottom was being held by something, felt around underneath the lower spoiler and felt the other 2-Silver Torx 20 bolts. Removed those and out came the Bumper cover complete. Set it inside the garage,(No lifting the car, opening the inner fender cap or removing the wheels or lights) Went back in and continued binge watching shows with my wife....Total time to remove the front was 25minutes, Thanks greatly to threads like this one and several others I read dozens of times to get an idea of what I would be dealing with, I also starred at the car in every direction looking for the bolts/rivets/wires I would be dealing with several days beforehand, The tools used were Trim removal Tool, both metal and plastic, Phillips head driver and a 10mm and 8mm socketwith small 1/4" drive ratchet.... Fast forward to this morning....Now the kids are off to school, it's daylight again, back to the job at hand.
Old 10-03-2019, 06:29 PM
OSilvera's Avatar
OSilvera
OSilvera is offline
OK.... Went outside. and continued the install. Pulled the brake ducts straight toward me while sitting in front of the car and they both came out with no trouble.
then did the same thing with the plastic pieces on either side of the radiator and as Chrunck explained in the first original post, those are not bolted in, they are snapped in on top and at the bottom held in place by way of Square keyed slots. those pull out easily enough, make sure to remove the temp sensor from the passenger side one ( if a left hand drive vehicle).
now I had access to the Intercooler, l loosened the two hose bands on either side, removed the 2 torx 20 screws on either side of the stock intercooler. and a few wiggles and out came the stock one. I removed the two rubber grommets from the intercooler and installed them on the Helix.. As quickly as the old one came out, I put on the new one. Although much heavier and bigger, it went on without much fuss. reached under the car to help get those hoses on there right, made sure the bands were still in a place where I could access the tightening screw like I did before and then I first attached the two Torx 20 screws thru the grommets to secure it in place, then proceeded to secure the hose bands.. Once that was in, I replaced the two radiator plastic side pieces, attached the temp sensor and the two brake air ducts and started the car to make sure everything seemed good and it was.
Total time to do the intercooler swap 2 hours 30 minutes. This includes the 25 minutes last night and the install today and refit of the front bumper cover. Not including the other hour for the Horns.
Next I moved on to installing two Hella Horns in place of the factory ones. This took some doing and the horns alone took about an hour to fit, make the custom connectors and install. The car now has horns that sound like a small freight train... Love it.
Did a short video about the install.
https://youtu.be/AdsK5WjsR9w
Old 01-03-2020, 09:29 AM
WeBad_Paceman's Avatar
WeBad_Paceman
WeBad_Paceman is offline
Thanks for the write up, appreciate that very much.
Couple of questions;
1) Which mods did you have already existing on the car before you performed this intercooler swap?
2) Was there a note-able difference in performance after doing the muffler removal and intercooler install?
3) Is that muffler soley installed on the charge tube for intake noise reduction?
Old 01-04-2020, 08:56 AM
AWD_Rally's Avatar
AWD_Rally
Moderator
2) There is a slight difference in increased spool due to less turbulence. Very minimal.
3) It is solely installed for intake noise reduction.
WeBad_Paceman (01-04-2020)
ADAMSALTAMINI
How to
03-28-2015 08:54 AM
GLN305
02-21-2012 07:31 AM
mitemini
05-01-2009 06:10 AM
junior1459
01-06-2008 07:25 AM
Bahamabart
07-04-2005 12:20 PM
Quick Reply: Drivetrain Intercooler Installation Pics
