R58 Water Pump Replacement
Old 05-06-2019, 09:31 AM
pbkirby's Avatar
pbkirby
pbkirby is offline
Dealer recommends water pump replacement as its leaking, been leaking for 10K miles although must be very slow as not seeing noticeable drop in coolant from overflow tank. What else should I replace while in there ?
Old 05-08-2019, 04:29 PM
knt's Avatar
knt
knt is offline
Maybe change friction wheel, tensioner, water pipes and drive belt.
Old 05-16-2019, 05:26 AM
ECSTuning is offline
Received 1,964 Likes on 1,764 Posts
+1 check the thermostat housing and expansion tank on the bottom for cracks. If you see the replace it. On the thermostat, if it leaks you will see a small blueish liquid right on the top of the transmission housing, if no leaks. Then you are ok.
Check the drive belt also while you are there and of course might as well flush the coolant if its never been done.
Old 05-16-2019, 06:01 AM
Scudder44's Avatar
Scudder44
Scudder44 is offline
Jings, if it aint broke don't mess with it. Me, I would do the water pump and ancillary drive belt. The other parts recommended above if you have the cash. If the thermostat housing and rear water pipe are not leaking I don't see the need. Flush and refill with new coolant. The friction wheel maybe at 100K miles, Tensioner on a Gen 2 should be good for life of car unless someone damages it.
USNAE2
16
06-17-2022 07:17 AM
cheetoman
06-07-2019 08:55 AM
theimage
02-05-2018 07:13 AM
BigGar
04-23-2017 04:49 PM
Little Bean
R55 :: Clubman Talk (2008+)
12-26-2012 03:23 AM
Quick Reply: R58 Water Pump Replacement
