New Family Member - Page 11 - North American Motoring
New Family Member
Old 07-10-2018, 10:42 AM
Tigger2011
Tigger2011 is offline
Prototype-R
Thanks for the hands on experience with regards to bearing wear. Makes me feel a little better about spacing things out. Just spoke to Dan and he already sent the RMA info and will get with the parts guys to sort out the bolt diameter / part number issue.
Picked up the A94 Midnight Black Metallic base/clear coat as well as the adhesion promoter for the trim. Now to start prepping everything. I haven't seen photos of anyone running these flares with the splash guards. Hopefully I'll be able to heat and reshape the splash guards without messing them up. Spacing the wheels is gonna make splash and slinging more of an issue but there's no way I'm putting rally style splash guards on. Looking forward to finally being able to install the Ohlins on the front.
  #252
Old 07-11-2018, 07:03 PM
dube53
dube53 is offline
Originally Posted by Tigger2011 View Post
Vlad will never see those kind of numbers lol. Nor did I ever say he would. My intent in making the statement was to point out the increased capacity of the drive train and that the axles will be next. With Vlad my plan is to build as strong of a foundation as possible. First with the drivetrain then later in the engine. 100 octane race fuel and meth will get you to 400 but that would make a pretty impractical daily driver. God knows what it would take to get to 600 but I'll bet good money it wouldn't last very long.
I agree spacers will make it harder on the bearings. However, I know several track enthusiasts and even a professional driver running spacers to make the wheel base wider which increases stability and cornering power. Seems like there's always trade offs with performance.
Somewhere in all these changes I have to decide on a BBK as the factory Brembo's will not cut in on track when pushed hard. AP Racing, StopTech and TCE Performance has some nice kits but I'm also in discussion with EBC about a BBK for the Mini.
Cars are carefully designed by engineers and mods crafted by car enthusiasts.
I believe I can trust the the first ones. As for testing the physics laws, it depends if the purpose is intended on a racetrack or on public roads. I am sure an insurance company may question these facts if a car is heavily modified.
For 20 years, I lived in Vegas where some Cadillac guys were driving on 13" wheels with spacers. Believe me, I saw pretty weird stuff happening.
  #253
Old 07-13-2018, 06:51 AM
ECSTuning is online now
Welcome. Here to help out my fellow R58 owners. Taking mine to the PVGP this weekend. http://www.pvgp.org/
  #254
Old 07-16-2018, 01:36 PM
bugeye1031's Avatar
bugeye1031
bugeye1031 is online now
Moderator
Got some time this weekend to do a couple of little things that have been hanging out there on my to do list. Customer vehicles always take precedence over Vlad. Luckily he hasn't held it against me yet. I kinda got a little tired of the way the shifter boot looked so I used a rubber grommet to hold the boot half way down the shifter. I think its a nice improvement.
I also finally got around to installing the OCC. As I mentioned previously I don't care for the way most RX cans are routed, and based on feedback some users have been experiencing pressure buildup in the crankcase. I believe this is caused primarily by how the "clean" side is routed which provides insufficient vacuum under boost.
I used the factory Norma connectors by using a heat gun to slightly heat the factory flex tubing. This allowed the connector to be easily removed and they fit perfectly in a 3/4" hose.
A 3/4" hose will also fit nice and snug over the clean side output with a little oil on the inside of the tube.
These lines were then connected via a 3/4" x 3/4" x 5/8" Tee fitting and routed to the center port of the OCC. The aft port of the OCC was routed to the intake manifold with a 1/2" hose and a one way check valve. The check valve prevents the OCC from being pressurized when in boost. After the check valve there is a 1/2" to 3/4" adapter then 3/4" hose with the factory Norma connector going to the manifold.
The forward OCC port connects to a 5/8" line to the regular connection on the turbo inlet pipe. I purchased a larger one way check valve for this line from UPR. The check valve allows vacuum draw under boost but prevents air being pulled through the OCC and into the manifold when not in boost.
Here's everything put together. My apologies for the dirty engine but I didn't have time to clean it up and was starting to loose daylight. I also had to fabricate a 2" x 7" L bracket to lower the OCC sufficiently so that the elbow fittings on the top of the can would clear the DDMWorks Intake. The elbows I'm not real crazy about either. The AN/NPT fittings on the OCC are 3/8" but the lines themselves have a 1/4" ID.
Installing the OCC this way allowed me to save all the factory hardware in case I'm not pleased with the results. The drain line out of the OCC is routed to the underside of the vehicle and tie wrapped to the subframe. This way I can just slide a small pan under Vlad and open the petcock. I'll be keeping an eye on what the OCC catches as well as any changes in oil consumption and post any surprises.
I've read that you tried another OCC arrangement in a later post, but I'm wondering where you ended up with your OCC. Did you decide to block off the passenger side? I believe that you mentioned that....did the design with the Tee not work? I have an RXPerformance OCC....not hooked up though...and I'm wondering if it will work. Thx
  #255
Old 07-17-2018, 10:35 AM
Tigger2011
Prototype-R
Yes I blocked off the passenger side port on the valve cover. Now the clean goes direct into the center port of the RX can. The rear exit port on the can is connected to the intake manifold with a one way check valve. This prevents boost from pressuring the can and back flowing into the intake tube. The forward exit on the can is connected to the intake tube and also includes a one way check valve. This prevents air from being pulled out of the intake tube through the can and into the intake manifold when not in boost. In essence the two external check valves have replaced the functionality built into the valve cover. System has been working great and maintains 1" of vacuum in normal driving and boost. The only time the crank case is not under vacuum is when the intake manifold is at atmospheric pressure when transitioning to boost. No great loss as the factory valve cover worked the same way.
Every three or four tanks of gas I open the petcock drain on the can and the oil filler cap. Since the check valves prevent air from entering the can if you don't open the filler cap the can wont drain.
The Following User Says Thank You to Tigger2011 For This Useful Post:
bugeye1031 (07-17-2018)
  #256
Old 07-27-2018, 04:10 PM
bugeye1031's Avatar
bugeye1031
Moderator
Thanks Tigger2011
I've converted to your setup....thanks for helping me understand how it works. I've only driven it a few miles, but so far, so good.
  #257
Old 07-31-2018, 09:07 AM
Tigger2011
Prototype-R
Glad to help. I used UPR 19mm check valves in the 5/8 portion of the lines on my setup but mine are the older design. The newer ones from UPR while more expensive look much more robust.
Now back to our fun with flares program. The folks at ECS were great about returning the other set of spacers and I've ordered two sets of the H&R DRA series 25mm spacers which have the 14x1.25 threads. Unfortunately, they don't appear to be available in black, only in silver so I guess I'll have to have them powder coated when they arrive. I've used Bullseye powder coating in Fort Lauderdale with great results in the past so I'll have them do these as well. The anodizing on the ECS branded ones was nice so I'm gonna miss that. I fiberglassed in three tie wrap anchors on one flare and fitted it using tie wraps. The problem there is in order to keep the flares from rattling the tie wraps have to be so tight that they alter the curvature of the arch. No bueno for caca. So looks like an adhesive it will be. I'll use a polysulfide based adhesive when the time comes. We use these types of sealant/adhesives in aviation a lot. Holds really well while still being flexible and is resistant to heat, cold, fuel, oil and various chemicals.
ECSTuning (08-13-2018)
  #258
Old 08-02-2018, 10:11 AM
favino1006
favino1006 is offline
Subscribing
  #259
Old 08-12-2018, 08:32 PM
Tigger2011
Prototype-R
Spent the last week when, I had time prepping the plastic trim pieces to be painted to match the body color. I used a 3" pneumatic orbital sander as a regular DA is too large to get into all the tiny curves. Wow! What a gigantic PITA it was to sand off the texturing on the plastic. But it beat paying someone $1,800 to do the job which was what I was quoted to paint everything. Started with 280 grit and finished with 600. Also ordered a lot of new clips for two reasons really. The red clips that hold the lower rocker panels on did not want to play nice and every single one of them broke. Most of the others could be reused but I figured since they're six years old I might as well get new. Also ordered new fender liner clips. A couple of those were a bit sketchy the last time I had them off. With the paint and clips I'm into this about $300 so far. The H&R spacers came in from our friends as ECS and they are the right size. Wohoo!! While I had the wheels off for test fit I tried using a string and altering the length and center location to draw smooth arcs for my cut lines on the fenders. None of which lined up well so next week I'll use .5cm pinstripe tape to freehand the lines. Everything should arrive this week and all the bits and bobs are in the paint booth. It's been a few years since I've painted professionally but we'll see how it turns out. This whole phase of the project has been taking way longer then intended but customers cars always come first. I've been driving Vlad all week with no rocker panels and no front spoiler or rear trim. Kinda looks like he forgot to put his pants on.
  #260
Old 08-17-2018, 10:09 AM
Tigger2011
Prototype-R
Short update. All but two pieces were primed and the flares are painted as well as some of the plastic trim pieces. I ran out of paint lol. Did I mention it had been a while since I painted. I'm using Sherwin Williams Automotive ATX series paint which comes already reduced. If you decide to do something similar be sure to get two quarts as one isn't enough.
Once everything is back together I'll address final polishing but so far I'm fairly happy with how it's going.
  #261
Old 08-19-2018, 11:23 AM
Mini Chris
Mini Chris is offline
I wish I was there to record your process. This would make an awesome video series, and something tells me you’re a natural giving explanations in front of the 🎥 😁
  #262
Old 08-19-2018, 09:36 PM
Tigger2011
Prototype-R
Haha yeah but then everyone would see all the mistakes I made along the way. "Oops forgot the adhesion promoter", "Dang thats fugly", "Ah snap its already reduced", etc..
The good news is our plastic panels are impervious to any solvent I've tried (mek, iso, paint thinner, acetone, methanol, etc.) so wiping them down is easy at least.
  #263
Old 09-02-2018, 05:52 PM
Tigger2011
Prototype-R
Planned on finishing up the flares last weekend but had a client that wanted a tune on Saturday. So Sunday I got the right hand side done. Drove Vlad for a week with one side done lol. Yeah I'm that guy. Finished the rest this weekend so a couple of photos are due. First up trusty tools for cutting out the arches.
Next up using pin stripe tape to layout my cut lines.
A little cutting action.
After cutting I used a round sanding roll to smooth everything out and applied a single stage midnight black metallic paint to seal the cuts. After that it's apply the adhesive and the flares which I let cure overnight. Next up was reinstalling the Mini splash guards which had been sanded and painted. Needed a bit more heat to alter their shape to fit with the flares. I also placed new double sided black foam tape to hold them in place along with the factory clips and screws. One clip on each couldn't be reused however because the RSI c6 flares don't have the same lip as the OEM.
Pretty happy with how it turned out. Still need to install the front Ohlin's but couldn't wait and took it for a spin. One thing I noted is the 25mm spacers seems to have made the ride a little softer. Not much but thought it worth mentioning. I'll try and get some better shots after I've had a chance to install the Ohlin's and clean Vlad up.
  #264
Old 09-03-2018, 12:26 PM
Mini Chris
My 🎩 goes off to your handiness sir. Vlad is looking good Excited to see how the suspension install goes
  #265
Old 09-04-2018, 05:44 AM
Tigger2011
Prototype-R
It stopped raining yesterday evening so I was able to finally install the front Ohlin's. Same dampener setting as the rear. Adjusted the front wheel gap to a fingers width. Still need to bring the rear struts down some to match the front. Took Vlad out for a little spirited driving and headed for some rough roads as well. Wow, the Ohlin's are outstanding. No rub anywhere with the flares. The ride is better than stock or any other coilover I've driven. They just eat up imperfections in the road without becoming unsettled. No crashing or jarring. Wasn't able to really push it hard though as the roads are still damp. Will update with clearance photos later today.
  #266
Old 09-04-2018, 10:28 AM
Tigger2011
Prototype-R
Clearance
Here's a few shots of clearance both brake and wheel.
  #267
Old 09-05-2018, 08:23 AM
jtr58's Avatar
jtr58
jtr58 is offline
Been admiring this car and your work from afar for awhile now. Congratulations. I would imagine you're not finished so I look forward to seeing what you do next.
  #268
Old 09-05-2018, 08:46 PM
Tigger2011
Prototype-R
Thanks. Other Mini enthusiasts ideas and input are always welcome. Its funny though how one mod just leads to another.
Up next It looks like I'll finally be able to install the wideband O2 and ethanol sensor system. Among other things, Im curious to see how the local E85 in South Florida checks out in the winter months.
  #269
Old 09-11-2018, 06:44 AM
Cool, you are one of 2 widebody/flare MINI R58 i have seen.
  #270
Old 09-17-2018, 10:32 AM
Tigger2011
Prototype-R
Removed the boost gauge since that information is indicated on the boost controller, and installed the E85/Wideband gauge. Besides displaying ethanol content and AFR or Lambda it can also display fuel pressure on the low pressure side as well as fuel temperature. I still need to put together the right connectors to use the fuel side of the gauge. It can display a single function like below, duel function with one larger than the other or all four functions. You can also set an alarm if the low pressure side drops below a point that you define. These options can be set from the gauge or through the LM Programmer software and all values can be data logged with LogWorks3 software. In addition it has various outputs that can be configured as inputs for a engine ECU that has the capability. My apologies for the crappy photo. Shaky Jake with the camera here.
hr1
Prestige MINI
09-28-2015 02:19 PM
Quick Reply: New Family Member
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Your question will be posted in:
