R58 Should I go K&N for my air filter?
As I rolled my 2-year-old Coupe over to 50K miles, it's time for maintenance work again. Checking with my local SF) MINI dealer, they checked the key fob and say I need "only" an oil change--and an engine air filter. ($400 for just that, to boot.)
I asked about switching to a K&N filter, having heard about their alleged benefits before but never having pulled the trigger. The reply was they were OK, but to avoid the "oil-based" one, as that oil could get into something that would cause problems (I forget exactly what she said). She also said it's likely increase performance--but decrease gas mileage.
Me, I'd rather "upgrade" if I can eke out an extra mile or two per gallon. I already found my mileage dipping a bit after changing out 2 tires to highly rated low rolling resistance ones, so I don't want to find my MINI trending down further toward 30 MPG; I'd rather find ways to push it toward the 40 mark (it'd been getting around 38 for the first year and a half I owned it).
So what does the hive mind say about K&N?
unless your filters really bad i'll be surprised if you pick up anything significant, unless you subconsciously drive it that way.
i think most of k&n's filters are oiled though, and not the best "filtering" - i'd just go with oem or check if amsoil's got anything that fits
Wait, what? $400 for an air filter? Or for that, and an oil change? WOW. Both are pretty easy DIY projects; the air filter doesn't even require getting under the car, and a good Mahle air filter is about $14 or so.
You can google "air filter myth lose mpg dirty" and get a bunch of hits, but the general theme is that modern engine control systems manage the air fuel ratio such that your fuel economy shouldn't be affected by a dirty air filter. A really clogged one might reduce overall *power* some, but it would still be running as cleanly as the system can manage.
Back in the [carbureted] day, a clogged filter *would* cause a richer mixture, much like having the choke on all the time, thus adversely affecting MPG. No chokes, or carburetors using them, these days.
A new K&N or an oiled foam air filter are oiled just right at the factory. The problem with oiled air filters comes when they are cleaned and re-oiled. Some people put too much oil on them and droplets of oil get on the mass air flow sensor causing it to malfunction and cause runnability problems.
Dave
Dave
eliseo1981
Sep 4, 2015 02:33 PM
