R57 added LED lightbar to front grill
This is exactly what I'd like to do except I'm hiding it behind the grill.
Can you explain the wiring? Does power come from headlights or direct from battery? I test wired my light bar with power from the battery today and I fried my FRM which is now being replaced for something like $600.
Howdoes it only come on with high beams? Any chance of pictures of the wiring?
basic wiring for 'added' lights
notes:
1. picture implies everything runs to one SAME ground. In a car, the chassis is the ground so the physical location doesn't matter, so long as you are at a ground - typically bare metal body work.
2. this shows a simple manual toggle switch but you can make this something else. Make it the high beam trigger and they come on with high beams. Use the HB trigger AND a switch and they can come on only with the BH. Make it a line to fog light power and same effect but with the fogs.
3. Want to add air horns .... same basic layout ... a power wire to one of the horns becomes the trigger (pole 86)
notes:
