R56 Things you didn't know about your R56 MINI
Old Nov 19, 2008 | 08:47 PM
  #1651
rippymcs's Avatar
rippymcs
Originally Posted by Sowellman
I think there's a setting where if you unlock your car but for some reason you never open the door, such as if you got sidetracked by something else and never entered your car, it will lock itself after a prescribed time.
Originally Posted by rippymcs
Only auto-locking feature is for after you turned the car on (after 10 sec or after certain speed or both).
Originally Posted by bhelton
This setting should be on the OBC with the auto-locking that turns on when you go. There's an arrow icon (locks when you take off) and a clock icon (locks after a certain amount of time if the doors aren't opened). You should be able to cycle through until one or both of these are on.
That isn't part of the alarm system, which I presume would control the re-arming function if there is one.
So, apparently there isn't a feature that auto re-locks (re-arms) the car if you accidentally disarmed the car.
Also, if you unlock the doors while the car is on, the auto-locking will not activate again until the car is turned off and turned back on.
Old Nov 20, 2008 | 05:11 AM
  #1652
bhelton's Avatar
bhelton
Originally Posted by pilotart
I found that with the key/fob "Two Clicks to UnLock the rest of the car" setting; often left me with locked boot and gas door.
So, I've just tried the passenger door. Does the one click option unlock everything at once, including the boot and gas door?
Old Nov 20, 2008 | 07:20 AM
  #1653
pilotart's Avatar
pilotart
If you have it set for 'one-click' un-lock, you will notice the passenger door lock button pop up and the boot and gas door will also be unlocked.
With the 'first-click' driver door only unlock, the boot and gas door also remain locked until second click (or trip of center toggle switch).
Same thing would be true with any of the 'auto-lock' features activated and you just unlock driver door to exit.
For me, it is enough that one click of 'Lock' locks everything and prefer that one click also un-locks everything.
One other thing to keep in mind is that you can open a locked boot with key/fob, but when closed it will be locked again.
Comfort Access protects by not 'auto-locking' boot if key/fob is detected inside, but standard system does not.
Old Nov 20, 2008 | 08:44 AM
  #1654
bhelton's Avatar
bhelton
This got to be a real pain the other day. I had tested putting the fob in the boot and carrying the key and it seemed to lock ok. When it came time to do it for real (I as running a race in the race so I didn't want the fob), I tossed the fob in the boot and closed the hatch and it popped open again. Turns out, when I tested it, the MINI knew my wife's key was not in the car too, so it allowed me to lock one in, but we were both running the race so we had to put both our fobs in the car. I ended up carrying the key part with me and placing the fob underneath the bonnet. My wife congratulated me and told me I outsmarted my car.
Old Nov 21, 2008 | 07:57 AM
  #1655
Ken G.'s Avatar
Ken G.
I think part of the problem is how the manual is written. I found where it documents the option to have all the door locks open with one push of the fob button, but it took a lot of reading to find it. Instead of listing all of the customizable computer settings in one spot, each is located in a separate section based on what was being set. For example, the passing signal setting is in the turn signal section, door locks setting in the door locks section, etc.
There's so many options in the Setup menu, Mini should really add an appendix to the manual that lists what each Setup item is and what each sub-item does, with section references to get further details.
The downside of doing this is it would take away the joy of discovering unknown fuctions of your Mini. And worse yet lessen the posts made here; where's the fun in that???
Old Nov 21, 2008 | 08:28 AM
  #1656
Browser_23's Avatar
Browser_23
Regarding unlocking the doors. I have comfort access so use the small black button on the door handle to unlock my door. I have it set so only the driver door unlocks. My question is with the fob, if you push the unlock button twice it first unlocks drivers door (if that is how you have it set) then a second push unlocks the rest of the doors. With comfort access using the small button on the door handle it does not seem to do this, it only unlocks the drivers door or all depending on how you have it setup, I can't seem to make it work like the fob with the 1 click, 2 click method. Is this correct?
Old Nov 21, 2008 | 08:41 AM
  #1657
x uh oh x's Avatar
x uh oh x
I think the manual was actually written that way so that the techs who "prep" the car for "delivery" to the customer can set it up first. But that's just a guess....
Old Nov 21, 2008 | 09:14 AM
  #1658
daffodildeb's Avatar
daffodildeb
That may have been true for pre R56s. Now the customer does everything. My car just had defaults, and the MA showed me the process of inputting my wants and desires.
The real problem is just that we speak English. Car manuals are written by Greeks who speak Italian, but no English. In case you doubt that unlikely combination, be advised that I had a TOOTH filled in just such a situation this past May, on my last trip over the Pond! It was an interesting experience--ask me about it some time...
Old Nov 21, 2008 | 09:32 AM
  #1659
bhelton's Avatar
bhelton
How do you set up the comfort access to unlock all the doors at once when you push the button on the door handle? Is it the same setting as changing the key fob?
In answer to your question, I don't think it's possible to set up the one-press two-press method for the door handle.
Old Nov 21, 2008 | 10:03 AM
  #1660
TheBigNewt's Avatar
TheBigNewt
Yeah it is. It bugged me that it only opened my door so I changed it. Same with the fob (I don't use that though.)
Old Nov 21, 2008 | 10:08 AM
  #1661
Browser_23's Avatar
Browser_23
Thanks. I'll have to look at my setup again and try it.
Old Nov 21, 2008 | 10:15 AM
  #1662
Sowellman's Avatar
Sowellman
In this case, the problem was caused by translating the manual from British.
Old Dec 3, 2008 | 09:08 PM
  #1663
TheBigNewt's Avatar
TheBigNewt
When you use the heater in the Auto mode heat comes out of all the vents, including the defroster. That's nice, I never need to defrost the windshield and a little heat comes out of the dash vents too (the floor gets the most). I like it.
Old Dec 4, 2008 | 07:07 AM
  #1664
iwashmycar's Avatar
iwashmycar
yeah ive noticed that too, especially in cold rain.. no fogging and still warm!
Old Dec 4, 2008 | 07:25 AM
  #1665
tjtull's Avatar
tjtull
May be a dumb question but how do you specifically select "heater"? Is it just a temperature adjustment? Or will it actually say heater?
Old Dec 4, 2008 | 08:21 AM
  #1666
pilotart's Avatar
pilotart
With the 'Auto' it just checks the interior temperature and automatically sets the outlets and heat for you.
It Does have buttons to select defrost, dash or floor manually as well, but temperature is still automatic, according to Hot/Cold setting.
The 'MAX' button puts in re-circulate and Highest Fan setting, or at end of upper and lower Temperature settings, there are "Hi/Lo" that give High Fan, but not re-circulate.
On auto, have noticed A/C lite is on and that removes moisture from air, or you can press the snowflake button and turn it off.
Old Dec 4, 2008 | 08:56 AM
  #1667
tjtull's Avatar
tjtull
Cool, just making sure I wasn't missing the "heater" selection. I have the A/C light on during morning drives, my windows fog without it. In the evening it's fine to turn it off.
Old Dec 4, 2008 | 09:03 AM
  #1668
Tu13es's Avatar
Tu13es
Also, it seems to defrost the windshield for longer if it's colder out (or maybe that's just because the car takes longer to warm up). After a while it seems to move to mostly middle and lower vents.
Old Dec 4, 2008 | 02:38 PM
  #1669
Ken G.'s Avatar
Ken G.
Makes me think I should've bought this package. Sounds pretty neat.
Old Dec 4, 2008 | 04:36 PM
  #1670
toolazyforalogin's Avatar
toolazyforalogin
I should've written it down when I read it in this thread b/c now I can't find it....how does one unlock all the doors at once on the first "unlock" press. What does the icon look like in the menu? I wish the manual was more thorough and organized.
Old Dec 4, 2008 | 04:50 PM
  #1671
Oxybluecoop's Avatar
Oxybluecoop
It's a little padlock icon.
Old Dec 4, 2008 | 05:28 PM
  #1672
toolazyforalogin
ty I will look tomorrow and see if I can find it.
Old Dec 4, 2008 | 06:54 PM
  #1673
Eoff's Avatar
Eoff
In a nutshell, here's what you do:
1. Press the button in the turn lever until it says, "SET/INFO".
2. Press and hold the button.
3. Press the button until you see "SET" with the key symbol and the check-mark on it.
4. Press and hold the button.
5. Press the button until you see a miniature car with the left door open.
6. Press and hold the button.
7. Press the button until you see a miniature car with BOTH doors open.
8. Press and hold the button.
Now, the remote you are using is programmed to unlock the entire vehicle in one press, which is my preference.
Old Dec 4, 2008 | 07:31 PM
  #1674
toolazyforalogin
Thanks for taking the time to describe the process - it is appreciated!
Old Dec 4, 2008 | 08:59 PM
  #1675
minim8o's Avatar
minim8o
I'm so glad I have the Navi screen to see & set all that...
