R56 N14 JCW persistent smoke/oil in cylinder after head work
Old Mar 2, 2026 | 03:17 PM
dez's Avatar
dez
Hi All,
I've been having ongoing issues with my 2011 (pretty modded) N14 JCW blowing smoke out of the exhaust. I know these cars are notorious for oil consumption and general issues, but I had headwork done (the second time beginning of 2025) it seemed to resolve the issue but then after driving there car about 500 miles it came back. Working with the shop that did the work, we've now had the machine shop redo the head, they didn't put new guides in the first time 😡 but after putting it all back together it still is smoking.
The shop that has the car is trying to make ti right but they can't seem to identify where the oil is coming from. They admittedly said they try not to work on modded cars...
I expressed my uncertainty that it was a head issue but the shop wanted to rule that out. But now they are saying they don't know what to do.
The car still drives amazing except everyone behind me is getting smoke screened Spy Hunter style. If it were rings or lowerblock issue the car would drive like crap correct? Or at least be throwing misfire codes?
Below is some more detail about whats going on. Pictures of the cleaned up head and scoped images after the test drive showing oil in the cylinders. Any help will be greatly appreciated 🙏.
Symptoms:
  • Persistent blue/gray smoke (oil).
  • Typically doesn’t show until warm (~7–10 min city driving), then most noticeable on acceleration / under load(e.g., pulling away from a stop).
  • Originally saw evidence of oil build-up/fouling; at one point it seemed concentrated mainly to cylinder #1 & #3. Now after reinstall after third head job its in all 4
History / work performed:
  • ~3,500 miles ago: head work (rebuilt used head).
  • ~900 miles ago: oil found in cylinders #1 & #3 → valve job performed.
  • After ~500 miles post valve job: smoke returned; now seems in all cylinders after 3rd head job.
Diagnostics so far:
  • Leak-down good.
  • Compression test now shows all cylinders good.
  • Charge pipe / intercooler shows minimal oil (not a lot of compressor-side pooling).
Recent attempt / updates:
  • Valve cover/PCV assembly was replaced during the last valve job.
  • Head came back off: lots of caked carbon. Machine shop verified head is good.
  • Important detail: last time the head was resurfaced, the shop did NOT replace valve guides. This time they replaced the guides (and did the head work properly).
  • Reassembled using stock head gasket.
  • Still smoking after reassembly.
What I’m trying to figure out now:
Given good compression, minimal oil in charge pipes, new guides/seals, and oil still visible in cylinders — what are the most likely remaining causes?
  • Valve seals installed incorrectly / stem wear despite new guides?
  • PCV/intake oiling biasing one cylinder (even with new valve cover)?
  • Oil control rings stuck/coked (even with good compression)?
  • Turbo issue (wastegate play / turbine-side leak), though that wouldn’t explain oil in cylinders unless it’s getting into intake?
If anyone has a recommended “next best test” (or a known N14 gotcha that matches warm + under load smoke), I’d really appreciate it.
Old Mar 2, 2026 | 03:55 PM
Maybe, maybe not's Avatar
Maybe, maybe not
Community Builder
Community Influencer
Below is what AI thinks. It's on your list.
Since the car drives perfectly (good compression) but consumes oil and smokes under load, the most likely culprit is stuck or clogged oil control ring. Standard compression and leak-down tests cannot detect this failure because they only test the top two "compression" rings, which are sealing fine; the bottom "oil control" ring is likely gummed up with carbon, allowing oil to remain on the cylinder walls and burn during combustion.
The "Drives Amazing" Paradox
Why Tests Failed
Your engine is passing the compression test because the top two rings (Compression Rings) are doing their job—sealing combustion pressure. The smoke is caused by the third ring (Oil Control Ring) failing to scrape oil off the cylinder walls on the downstroke.
The Symptom Match:
This specific failure causes smoke after warm-up and under load (when oil is hot/thin and volume is high), but rarely causes misfires or power loss until it gets catastrophic.
The N14 Factor:
These engines are notorious for coking up the oil rings due to high heat and extended oil change intervals. Once that bottom ring is stuck in its groove, no amount of head work will stop the smoke.
As you mentioned there are other possibilities as well.
Old Mar 2, 2026 | 04:34 PM
dez's Avatar
dez
Thanks @Maybe, maybe not . I too have been trying to diagnose with AI since the shop seems ill equipped.
This is what AI said when I specifically gave it the images of the oily cylinders:
Across all three, the piston crown isn’t just “sooty”; it has fresh-looking, glossy dark areas and amber/brown wet staining that looks like liquid oil that’s been heated. Importantly, the wet-looking area appears localized to a quadrant, not an even “oil sheen everywhere.”That pattern is more consistent with oil entering from above (valve/port side or intake ingestion) than classic oil-control ring failure, which tends to:
  • wet the perimeter more uniformly, and
  • show vertical “wash” streaks on the cylinder wall (carbon scrubbed off in strips).
You can’t conclusively call it from piston-top photos alone, but these don’t scream “all-around ring oiling” to me.
I think we need to do a mid-stroke bore photos to check for wash stripes or not
AI also said:
  • Wash stripes across multiple cylinders → rings/oil control.
  • No stripes + oily intake valves/runners → intake/PCV route.
Old Mar 2, 2026 | 05:10 PM
Maybe, maybe not
Community Builder
If you are interested, AI also detailed a test for stuck oil rings...
Since the head is currently on the car, you can try a "Piston Soak" before committing to a bottom-end rebuild. This is a known "Hail Mary" for the N14/N18 engines.
Protocol: The Solvent Soak
Goal: Dissolve the carbon locking the oil rings without disassembling the block.
Prep: Remove spark plugs. Level the pistons (turn crank so they are mid-way).
Solvent: Pour a mix of B12 Chemtool (aggressive) and ATF/Oil (lubricant) into each cylinder.
Soak: Let it sit for 24-48 hours. Top off if it drains through (it should drain if rings are loose, but if they are stuck tight, it might hold).
Agitate: Occasionally hand-crank the engine a few degrees back and forth to work the rings.
Evacuate: CRITICAL - Suction out all fluid and crank with plugs OUT to prevent hydrolock.
Run: Change oil immediately. Drive it hard.
If this reduces the smoke, you have confirmed stuck rings. If it does nothing, the rings may be physically collapsed or the cylinder walls glazed/ovalized, requiring a rebore.
Zamspeed
R55 :: Clubman Talk (2008+)
Apr 1, 2025 12:56 PM
oldrocker25
Nov 2, 2022 07:04 PM
Its_The_Jockmo
Mar 25, 2020 08:28 AM
CantComplain
Feb 11, 2020 05:32 PM
deuce40
Aug 30, 2015 11:33 AM
