North American Motoring
North American Motoring (https://www.northamericanmotoring.com/forums/)
-   R56 :: Hatch Talk (2007+) (https://www.northamericanmotoring.com/forums/r56-hatch-talk-2007-136/)
-   -   R56 2011 mini cooper s crank but won't start (https://www.northamericanmotoring.com/forums/r56-hatch-talk-2007/367765-2011-mini-cooper-s-crank-but-wont-start.html)
yyj3869 Feb 28, 2024 05:20 PM
2 Attachment(s)
One of my friend has 2011 mini cooper s with 93k miles and car was running about a week ago but died after filling up at a gas station. it would crank but it wouldn't catch like video attached.
he replaced the fuel pump 3 months ago. what else could it be?
https://cimg9.ibsrv.net/gimg/www.nor...547e40d862.jpg
https://cimg8.ibsrv.net/gimg/www.nor...dce1d1b348.jpg
mkov608 Mar 1, 2024 01:54 AM
If you have to ask that question, you need the services of a professional diagnostic guy. When I see a new problem like the one you're describing, the first question I ask is, what did you just do to the car (besides the fill-up)? What is the maintenance/repair history for the past 12 months? The basics ... are you getting fuel, spark, air? Has the timing slipped?
yyj3869 Mar 1, 2024 09:12 AM
Thanks for the reply. sorry since it's one of my friends car so sorry about the explanation. I've attached current service history.
mkov608 Mar 1, 2024 09:34 AM
Oh My! You've spent more than the car's worth. I'd take it back to the place the performed all those repairs. There should be some type of warranty on their repair work.
yyj3869 Mar 1, 2024 09:40 AM
Yeah I know. As I mentioned, It's not my car lol. I think my friend was ripped off from the shop. I was literally surprised how much he paid for. I've checked the review on yelp and noticed that the shop usually overcharge service fee to the customers and unfortunately the shop is almost 100 miles away so I don't think he will take it back to the shop.
I'm thinking of buying this car at $3000. it ran only 93k miles.
mkov608 Mar 1, 2024 09:46 AM
Good luck.
AidanB Mar 1, 2024 05:12 PM
Do you have a bmw code reader? I bought a mini from auction that would crank but not start. It was throwing codes about not being able to adjust the vanos solenoids IIRC. You can try swapping the intake and exhaust vanos sensors (on the top of the valve cover, held down with a single bolt). Or, if you get unlucky like I did, the timing chain was completely snapped in half. You should be able to watch through the oil fill cap and make sure that when cranking the cam shafts are moving.
If its not something obvious like that then its back to the basics like mkov said. Might be a bad coil or bad signal from the DME to coil, might be some obscure sensor, might be a bad fuel pump (if the sketchy shop replaced his hpfp with a cheapy ebay one to scam him it could've died after 6 months). Hopefully the code reader helps you track it down
Good luck
yyj3869 Mar 2, 2024 02:49 PM
Good luck
I've checked with the bluetooth obd scanner and it didn't have any codes as below. I picked the wrong day to check the car up since it's raining hard... I opened oil cap and took a picture of inside and see and noticed that there were oil sludge so bad.
I also tried to start few times and it was same as video but while I was checking under the hood and tried starting again but the car didn't even crank..
https://cimg5.ibsrv.net/gimg/www.nor...49c5cb147b.jpg
https://cimg8.ibsrv.net/gimg/www.nor...114f52336f.jpg
https://cimg0.ibsrv.net/gimg/www.nor...1c8a36d356.jpg
AidanB Mar 2, 2024 05:58 PM
That seems strange that it suddenly stopped cranking, maybe you need to look into some blown fuses or a leaky fuse block? Its possible that the fuel pump relay got corroded and now maybe the starter relay went too? You should probably check the battery condition first though, see if it'll crank again with jumpers or a better battery. Also if that's a generic OBD2 code reader it might not pick up everything, do you know for sure it reads the BMW specific codes too?
yyj3869 Mar 3, 2024 08:10 PM
Yes when I went to check the car, I pulled out fuel pump fuse (F46) from passenger side fuse box and checked that fuse was fine so I plugged it back but I think I should have disconnected battery before I pulled out fuse and today the seller told me that fuse was blown (not sure about that) and he took the battery at autozone and charged the battery and installed battery again and it started cranking again fortunately, however it still doesn't start up..
