R56 How dirty are my intake valves at 23k miles?
Old Nov 5, 2022 | 01:46 PM
Lex2008's Avatar
Lex2008
I put a new motor in approx. 23k miles ago, No catch cans (until last few hundred miles). I was changing throttle body, vacuum solenoid (making crazy kazoo noise) and vacuum canister and hoses and was a little shocked at the state of the intake valves after only 23k miles.
Old Nov 5, 2022 | 05:02 PM
Lex2008's Avatar
Lex2008
I cleaned them without walnut blasting because I don't have the adaptor that faces backwards...I used Berryman's and some brushes.
Old Nov 6, 2022 | 04:53 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
N14? Based on what I’ve read, looks normal to me. What are your driving habits? I understand that short trips around town will cause the build up to come quicker. Longer highway trips tend to extend accumulation a little better.
Old Nov 6, 2022 | 05:14 AM
Lex2008's Avatar
Lex2008
N14 turbo yup. Yes indeed this car sees mostly city use. Looking at other pics of n14 valves this looks pretty standard.
Old Nov 6, 2022 | 05:14 PM
Lex2008's Avatar
Lex2008
I have a walnut blaster and 80-gallon compressor but I didn't have enough walnut or the vacuum cleaner attachment I didn't feel like making a huge mess doing this.
Is the only good option the metal BMW made vacuum hose adaptor?
Old Nov 7, 2022 | 03:50 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
There is a 3D printed version available from ECS, but the metal adapter will last for multiple blastings.
Old Nov 7, 2022 | 06:28 AM
Lex2008's Avatar
Lex2008
Thanks nj. I'll order it for the next cleaning.
My other direct injection car (Japanese) takes about 2x longer to get this dirty.
Old Nov 14, 2025 | 11:47 AM
Whisky B's Avatar
Whisky B
Not all catch cans are the same. I just swapped a used Mishimoto 10oz for a Turner 8oz with baffles and improved connectors. While installing the new hose can I noticed some visible oil sitting inside the return line. However, the Mishimoto was a simple line in/line out design with zero baffles and I figured it would not be 100% effective. Considering it managed to consistently capture a significant amount of oil over the course of 6000 miles (2 oil changes), I figure it's better than nothing. Send a little Seafoam down the tube every couple years and you should be good to go.
Old Nov 14, 2025 | 12:01 PM
Lex2008's Avatar
Lex2008
Its better than nothing but not much with the addition of potential leaks in the lines and freezing.
Old Nov 14, 2025 | 12:08 PM
Does not look that bad, mine was really greasy and took a couple brushed as they got covered in gunk. The pick i used really helped, then the blaster did the rest. Pick=>Brush=>blaster thats how i did it.
https://www.northamericanmotoring.co...ke-valves.html
Greasy look, tar type.
ShadowBethesda
Jul 15, 2019 08:16 AM
Sstrickstein
Mar 17, 2016 08:43 AM
tintman718
Jun 28, 2014 03:16 PM
Tigger2011
Oct 17, 2013 09:42 AM
Bang110
Aug 17, 2008 06:12 PM
