R56 N18 limp mode with no codes..but oil smoke
Old Aug 29, 2021 | 08:40 AM
ditc's Avatar
ditc
N18 limp mode with no codes currently…but exhaust smoking at idle
Hi all,
Car is a 2012 with N18 engine, 60k, oil changed regularly and often.
I did get a code “33FE - Engine oil pressure control plausibility static Pressure too low” yesterday. Car went into limp mode and I parked and got the scanner out (I have the NT530).
I couldn’t think of a reason for this, the car had been running fine, just completed a 100+ mile drive prior. Dipstick shows oil is there, up to 3/4 to the top of the dipstick.So I bought a quart and dumped it in and now I dipstick is at full.
Anyway, so I cleared the code and started the car up again - the code did not come back. - a little rough start and some oil smoke out the exhaust..not good..but then settled down as I slowly drove again, but in limp mode..
So the code did not re-appear, no other check engine light or anything, but I am in limp mode and no boost. Also, revving past 4K RPM creates some weird sounds, like a ‘whizzing’ sound. And the idle is definitely more rough. And oil smoke is still slightly there out the exhaust though oil levels seem fine so whatever is burning oil is not burning much
Not sure where to start on this one. Oil pressure sensor? Oil pump, vanos? I had the oil pressure solenoid issue fixed by a reputable shop about 7k miles ago, so I am assuming it’s not that. Any thoughts on where to begin? Again, there’s no check engine light and no codes, other than the above and that has not re-appeared since I cleared it.
thanks for any suggestions
Last edited by ditc; Aug 29, 2021 at 05:15 PM. Reason: Removed observations that were not relevant.
R.Gerbec
Aug 26, 2020 07:44 PM
Chris Wallace
Jul 11, 2019 02:08 PM
Pootietang
Apr 2, 2017 02:13 PM
studio47
Dec 4, 2015 08:46 PM
tattman23
Sep 18, 2007 12:49 PM
