R56 Question regarding tunes and coolant temps
Old Dec 2, 2020 | 05:11 AM
hxkenneth's Avatar
hxkenneth
Hello - my understanding is that the thermostat on the N14 opens at 105C automatically. How are tunes able lower coolant temps? Is there a electronic control for the thermostat as well? I noticed there seems to be 2 connectors on the thermostat, one that goes to the temp sensor and another that seems to go somewhere else on the other side of the thermostat.
Old Dec 2, 2020 | 05:51 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
The temperature control is electronic and controlled by the ECU. When you get a tune, the temperature control target is changed, allowing for a lower operating temp.
Old Dec 2, 2020 | 03:32 PM
930 Engineering's Avatar
930 Engineering
Why lower coolant temps? It's designed that way for a reason (water and fuel diluted in oil).
Old Dec 2, 2020 | 03:37 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
The original Mini programming for the thermostat is 225°F. Later, Mini reduced the target temperature to 190°F when in "Sport" mode. Most tuners will adjust the thermostat target to 190°F at all times. Running more boost creates more temperatures, and a cooler thermostat target will keep engine temps in check.
Old Dec 15, 2020 | 10:02 AM
930 Engineering
I fully understand the aim behind that, but there's some downside. Since many if not very most tunes will give a richer mixture the issue of oil dilution (fuel) is even raised. Increased oil temps and extended daily distances will help, as well as shorter OCIs. It has its advantages to run a little hot.
Weedahoe
R60/R61 Stock Problems/Issues
May 17, 2019 08:56 PM
ssashton
Jun 2, 2017 04:57 AM
ahmedalsurmi
Oct 29, 2015 05:08 AM
ChrisJ83
Nov 25, 2013 04:32 PM
his15153
Oct 22, 2011 11:36 AM
