R56 Halogen to Projector (malfunction light)
Old Apr 25, 2020 | 10:07 AM
Charliefowle03's Avatar
Charliefowle03
I recently installed a set of Helix projector headlights into my 2007 Mini Cooper S and revieve the malfunction or "bulb out" light. I think thats what it is atleast. Can anyone help me figure why this is?
Indicator lamp error that appears after install.
Helix R56 headlights
Old Apr 25, 2020 | 01:28 PM
Gubi's Avatar
Gubi
I had the same headlights and the same problem. I had to turn off the high beam voltage check using Carly to make it go away. I think turning off the DRLs via the dash menu also worked.
https://www.northamericanmotoring.co...t-warning.html
Old Apr 26, 2020 | 09:55 AM
Charliefowle03
Thank you for the info. You get the Carly function only through full version?
Old Apr 26, 2020 | 10:18 AM
Gubi's Avatar
Gubi
Yeah, I needed the full version of Carly along with a compatible OBD2 adapter. I turned off the high beam voltage check.
There may be other ways to do it, but that worked for me. Perhaps you can find somebody locally with Carly, or a mechanic may have the system to code that out for you.
Did you try just turning off the DRLs in the dash menu? I think that also worked but I didn't play around with it much as I had the Carly anyway.
Old Apr 26, 2020 | 10:19 AM
Gubi's Avatar
Gubi
Also you made a smart move getting the Helix lights. They work way better than the stock halogens, which are dangerously bad IMO.
Old Apr 26, 2020 | 10:35 AM
Charliefowle03
Thanks again for the suggestions. I will ask my local shop. In the meantime, I would like to disengage the drls? Am I close in the menu here? Which one is the drl?
Old Apr 26, 2020 | 04:15 PM
Gubi's Avatar
Gubi
The first pic is the DRL setting. Looks like yours are off already.
Easy to tell. Start the car and leave the headlight switch off. Are the headlights off? Then your DRLs are off.
Old Apr 26, 2020 | 04:25 PM
Charliefowle03
Okay, that's what I was thinking. I always have mine set to Auto. Where if the lighting is dim, then they come on.. so at this point I will contact my local auto repair and see 9f they are capable of doing this. Can they do this, do you know, with like a standard scan tool? Snap on ect.
Old Apr 26, 2020 | 04:50 PM
Gubi's Avatar
Gubi
It's coding so I'm pretty sure you need something Mini-specific. A dealer who works on Minis can likely do it, but I doubt a general mechanic can.
Old Apr 26, 2020 | 04:51 PM
Charliefowle03
Okay. Thanks for the tip.
ForcedFed4
Jul 18, 2014 04:55 AM
Bodhiavo
Jun 30, 2012 11:55 PM
kellysean007
Dec 26, 2010 03:52 PM
liafia
May 6, 2007 02:00 PM
ecl3x
Dec 5, 2003 05:45 PM
