Go Back  North American Motoring > 2nd Generation MINIs > R56 :: Hatch Talk (2007+)
New AC compressor # has smaller diameter pulley >
R56 New AC compressor # has smaller diameter pulley
Old 05-28-2019, 05:52 AM
Lex2008
Lex2008 is online now
I installed a new SANDEN AC compressor in my 2008 R56S yesterday I ordered from ECS Tuning. It looked virtually the same. Original was also a Sanden.
After I got it on and put the belt on, I noticed the belt tensioner was almost resting on the alternator pulley. I then measured the pulleys and the new part # 64529223392 (original was 64522758145) is 1/2 an inch smaller. The 64529223392 supersedes the original for who knows what reason. (http://www.realoem.com/bmw/enUS/part...&q=64522758145)
I also installed a new DAYCO belt tensioner at the same time which has a different design for the arm. It is MM away from touching the AC pulley. Anyone notice that?
I wonder if I should get a shorter belt. (belt 11287604014 : 6K x 895) I know that their are 2 AC compressor part #s with different corresponding belts, but I double checked and mine seems to be the correct combo of belt (belt 11287566789 : 6K x 905) and AC compressor. Does anyone know if the belts are interchangeable?
original compressor 64522758145
New compressor installed part # 64529223392
DAYCO tensioner arm almost touching alternator pulley.
Old 05-28-2019, 06:28 AM
ECSTuning is online now
Hello, As noted on the redlines it requires 11287604014. Let me know when you get it and fit it so we can make sure everything is ok.
https://www.ecstuning.com/Mini-2007-..._Conditioning/
MINI Guru/ MINI Owner Since 2004 | Local Part Pickup Now Available
Old 05-28-2019, 01:14 PM
Lex2008
ECS Tuning,
Where does it state that? I ordered after speaking to your staff and they told me to order 64529223392 . They never told me to get a shorter belt to go along with it. The unit is installed. I assume I can get away with the shorter belt 11287604014 (894 vs 905mm)?
Old 05-28-2019, 01:27 PM
Hello Lex,
Can you see the red colored notes?
For belt 11287604014 : 6K x 895
Old 05-28-2019, 01:40 PM
Lex2008
Hello Lex,
ECS Tuning.
Yes I see that but your staff gave me that part over the phone number based upon my VIN. They never mentioned ordering a shorter belt. Come on man, this is why I order from ECS Tuning and not a million other places. To avoid these mistakes.
Can I just install the shorter belt 11287604014 ?
a
Old 05-28-2019, 01:59 PM
Oh, ok sorry they missed that. I will also update the system to make it more clear. Yep, get that shorter belt.
Old 05-28-2019, 02:58 PM
Lex2008
Mike P is over-nighting me the correct belt. Your system is mostly clear but your staffer made a mistake. We all do it.
Im just glad I can swap belts and not have to pull a compressor!
If anyone needs a new compressor, save $100 and get the newer compressor design 64529223392 and a smaller belt 11287604014 rather than accommodating the new compressor to the original belt.
ECSTuning (05-30-2019)
mach schnell
05-21-2009 10:21 PM
90STX
Drag Racing
04-11-2006 01:28 PM
jonnieoh
06-27-2005 07:00 AM
minicoopermike
10-16-2004 06:03 PM
05JCWS
10-04-2003 07:58 PM
Quick Reply: R56 New AC compressor # has smaller diameter pulley
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
