Turbo failure?
Turbo failure?
Just replaced my hpfp on my 09 cooper S which I had all the symptoms saying it was bad that issues fixed but now I’m only hitting 5psi max at wide open throttle, I hear it spool up to 5 then die down, bit of burning oil smell too I’m thinking failed turbo seals but figured I’d ask if anyone else has ideas
Burning oil smell was there but was running normal boost before doing the hpfp everything is still on and tight with no codes
They like to wiggle off or crack then work there way off:
https://www.northamericanmotoring.co...rbo-inlet.html
DomesticMuscle
Factory JCW Talk (2009+)
11-22-2013 08:46 AM
redbullfx2
12-05-2011 06:24 AM
