Electrical 2013 S rear fogs stopped working
Old 10-15-2018, 06:31 PM
Nui's Avatar
Nui
Nui is offline
I swear they worked before I made the LED switch.
The reverse lights work but not the rear fog. I put on the fog switch and the front fog works but not the rear.
Put in the original bulb for the fog section and still doesn't work.
What am I missing?
TIA!
Old 10-15-2018, 10:00 PM
S-2013's Avatar
S-2013
S-2013 is offline
Does the rear fog icon come on, is there a dedicated fuse?
Old 10-15-2018, 10:07 PM
Nui's Avatar
Nui
Nui is offline
Good question. I couldn't find the icon or switch. I'll look again...just downloaded a manual. Whoops. When the car is back I'll try the 'rear' fog light switch if its there. Ooops.
Old 10-16-2018, 01:22 AM
S-2013's Avatar
S-2013
S-2013 is offline
Rear fog switch is in the toggle bank under the HVAC controls. It's next to the passenger window switch and is separate from the front fog switch. You should get a "yellow" icon on the speedo face when on. If you installed LED bulbs, expect then to randomly flicker every few seconds due to the bulb check circuit. I did the same LED mod but coded the bulb check "off" using the Carly app.
Old 10-16-2018, 09:27 AM
Nui's Avatar
Nui
Nui is offline
Car just got back. There's no switch on the panel for the rear fog lights. Just a blanked out area. It certainly has them. Her mechanic said the computer might have fogotten the car has them and will need to be programmed.
Blanked out switch
Old 10-16-2018, 09:53 AM
S-2013's Avatar
S-2013
S-2013 is offline
Rear fog switch
Old 10-16-2018, 09:57 AM
S-2013's Avatar
S-2013
S-2013 is offline
I believe all 13 MCS's have the same lights in the rear bumper. It was an option to have them enabled with switch, symbols and icon illuminated on the speedo.
Old 10-16-2018, 02:08 PM
Nui's Avatar
Nui
Nui is offline
Guess this one didn't. Hopefully the computer can be programmed for it. Thanks for the clarification!
Old 10-17-2018, 08:13 PM
Nui's Avatar
Nui
Nui is offline
Just spoke to the mechanic. Without the optional switch as you have there's no programing that can be done. He said its a European thing and on US models the fog lights become a hard braking light.
Too bad. It gets foggy here and would've been nice to have them come on with the front fog light.
Old 10-19-2018, 04:23 PM
anew742's Avatar
anew742
anew742 is offline
The mechanic is wrong! In fact, getting them to work as brake lights requires rewiring and not just reprogramming.
I also have a 2013 Cooper S and I got mine working just fine!
Spoiler
All you need to do is buy a replacement switch and put it into place. Then reprogram the car with NCS Expert and an OBD-II cable. There's a lot of great posts here detailing the whole process - which is how I found out and got mine working.
I can send you links with more info/files if you want.
Old 10-19-2018, 04:29 PM
Nui's Avatar
Nui
Nui is offline
That would be amazing! Do I buy the switch at the dealer? Most importantly, is the wiring there ready to be hooked up? I imagined it would take a long run to the lights. Please send the links. Really, really appreciate it.
Old 10-19-2018, 05:47 PM
anew742's Avatar
anew742
anew742 is offline
The wiring and even the bulbs were already in place!
I got the toggle switch from Way Motor Works: https://www.waymotorworks.com/used-r...7-r58-r59.html
(link is for a used one, they also sell new. I bought used since it's half price and not noticeably different)
I reference this post for information: https://www.northamericanmotoring.co...beginners.html
And this one: https://www.northamericanmotoring.co...s-you-can.html
I got a cheap cable like this one: https://www.ebay.com/itm/BMW-INPA-K-...pid=1263694158 which works just fine
The reprogramming part didn't take very long, it just involved changing code from "nicht_aktiv" to "aktiv" lol
To get the toggle panel out, I just wedged a flathead screwdriver under each corner and shimmied my way across...not exactly elegant, but it worked
Sorry for the info dump! I don't have the time right now to explain properly, but I figured that this would be way better than nothing!
Old 10-19-2018, 06:14 PM
Nui's Avatar
Nui
Nui is offline
Just ordered and read the other threads. Can’t wait. Thanks again.
devilmotorsports
R60 :: Countryman Talk (2010-2015)
02-01-2016 12:54 PM
KeyPlayaJim
08-09-2013 07:14 PM
PawPaw
07-14-2011 08:53 AM
Apple
07-04-2008 12:19 AM
Dixie
18
12-09-2003 10:45 PM
Quick Reply: Electrical 2013 S rear fogs stopped working
