daily drivers only - OEM heatshield on/off?
If you daily a stock or modified R56 turbo; Please let me know if you:
A. still have OEM heatshield over the turbo (or aftermarket) B. have no heatshield at all Assuming you cool-down before you park the car/shut down, I dont think there would be any adverse affects. I would like to hear what others are doing and any issues you may have encountered (heat related or otherwise). Thank you |
Leave it on, its there for a reason. Especially since you are running Stage 2 tune.
OR, if you want to melt your valve cover, you can take it off... your choice. |
+1
Don't forget about bubbling the paint off the hood! |
obviously i wasnt clear enough - i dont need/want opinions from everyone. Ive edited so that OP says clearly "If you daily a stock or modified R56 turbo; Please let me know if you:
A. still have OEM heatshield over the turbo (or aftermarket) B. have no heatshield at all" without this information your words are a waste of everyones time/life/bandwidth etc. Thank you. |
I daily drive my R55 Clubman. (same engine) I still have the OEM heat shield, have a cat-less down pipe installed, run Manic Stage 2 map B, AND I have an AEM heat shield in place. I would NOT want to run without the OEM shield. I am even considering purchase of the Way Motors turbo wrap to keep heat more under control.
Heat shield
Stock heat shield, with a WMW turbo wrap. Mods are in my profile.
DO NOT drive without the heat shield you will melt the valve cover.
Our most popular thing to do is run our turbo wrap under the stock heat shield. Then I run the open scoop grill with the hood heat shield. https://www.waymotorworks.com/mini-c...5-r56-r57.html https://www.waymotorworks.com/wmw-tu...at-shield.html https://www.waymotorworks.com/mini-f...oop-grill.html |
Never without heatshield, at least wrap and turbo blanket
+1 heat shield always on.
WMW blanket, OE shield, NM shield
Me too, OEM heat shield over a Way Motor Works turbo wrap.
The fact that this component has the words heat and shield seemingly makes it an critical part but to answer your question mine is in place.
-Kevin |
lol... ive never had an issue with mine not being there.... no scoop warpage, no bubbling paint, no melted valve cover.... :no:
https://farm5.staticflickr.com/4799/...cd502eef_c.jpg |
The turbo wrap will improve the efficiency of the turbocharger by keeping the heat inside the turbocharger. A turbocharger is a heat engine after all.
I thought keeping the turbo cooler so the charge air is heated less would be ideal. Maybe that is too logical?
@ ohioJCW - THANK YOU! I know of only a few folks that run with no HS (you are now the 4rth) that have zero problems. A lot of why i want input from others is, I suspect its driver related and not the vehicle at all. **For example, I stay out of boost most of the time in my commute; if/when i do pound the throttle I always cool down below 950f EGT before shutting down the engine. I dont think I have as much risk of melting something as say.. someone who doesnt have temp gauges and just drives however and turns the car off like its a vacuum cleaner! ;p
**Thank you for everyones input so far |
Heat sheild on R57 Stage 2 RPM tune
Have a
Looks great, runs cool ... |
Originally Posted by cargusjoh
(Post 4405811)
Originally Posted by cornjuice
(Post 4405856)
**Thank you for everyones input so far BTW.... I just rolled 90k on my JCW |
