R56 Carbon Cleaning Help
Old May 26, 2018 | 05:53 PM
1Marine's Avatar
1Marine
Evening All... I finally was able to get to my mini this morning to carbon clean the valves. The valve are very dirty. I'm having trouble with my media blaster and looking for someone that may have done this before to lend over some advice. I've read the posts on here as to building a wand etc...I purchased the Harbor Freight media blaster.. I can't very much media to come out... I have my compressor set to 100psi but there isn't much flow..anybody have any experience?? I double checked to lines to ensure it wasn't plugged, I also checked the barb connected to make sure it wasn't to far into the media gun...
Attached Thumbnails Carbon Cleaning Help-img_8703.jpg   Carbon Cleaning Help-img_8706.jpg
Old May 27, 2018 | 02:33 PM
1Marine's Avatar
1Marine
So.. there was a small metal shaving shapped like a coned S that was lodged in the hose.. this allowed air but restricted the media...
Old May 27, 2018 | 08:32 PM
Pramuk's Avatar
Pramuk
Have you ever tried CRC intake valve and turbo cleaner? I think it might help a little bit.
Old May 29, 2018 | 05:21 AM
1Marine's Avatar
1Marine
got the Mini going... The cleaning took way longer than expected but as you can see above my valves were very dirty. I'd recommend doing this before you reach 94K like I did, it may save you some time. Thanks for all the help & PMs. The tech articles were outstanding I wouldn't have been able to do this without them.
Thank You
Old May 29, 2018 | 05:47 PM
mkov608's Avatar
mkov608
Install a Snow Performance Water/Methanol kit ... no more valve cleaning!!!
Old May 29, 2018 | 05:49 PM
mkov608's Avatar
mkov608
Some newer cars are using direct injection coupled with port fuel injection (the port fuel injection will keep the valves clean. Hopefully this will catch on with BMW/MINI.
Old May 29, 2018 | 11:19 PM
drea-min's Avatar
drea-min
Walnut blasting tols
Is this help in walnut blasting N14 engine?
Old May 30, 2018 | 08:48 AM
mkov608's Avatar
mkov608
No. It clearly says it's for an N54/N55 engine. Those are BMW straight 6 engines.
Old May 30, 2018 | 08:56 AM
drea-min's Avatar
drea-min
that’s what is available and have it already im sure it can be modified the openning to fit the intake on N14 manifold, the idea is just to keep the wallnut media and dust from exiting all over, its better than straight shot nozzle. Thanks
Old May 30, 2018 | 09:01 AM
You will need this, if you go the factory route. Lots of info here:
https://www.northamericanmotoring.co...-cleaning.html
mslatter
Mar 2, 2020 06:55 AM
tintman718
Jun 28, 2014 03:16 PM
fullymooned
Dec 20, 2012 07:20 AM
LeeW
Jan 31, 2011 08:22 AM
garageLIFE
May 22, 2003 08:33 PM
