R56 r56 n18 fuel pump won't turn on
Old 10-01-2022, 12:17 PM
rambatr56's Avatar
rambatr56
rambatr56 is offline
Hey all,
I've been reading through all the mini forums for the last week trying to solve my problem and am at a loss. My wife's 2011 r56 Mini Cooper s (n18 engine) randomly died on her way home a week ago. Pulled the code P0087.
I replaced the low pressure fuel pump and fuel filter. HPFP was replaced by the dealer 2.5 years ago. Car still wouldn't start. Also bought another fuse panel from a junk yard mini in case the JBE/K96 relay was the cause. Still no start.
Using my Foxwell OBD scanner I was able to manually force the fuel pump on and measured 12v at the connector pins. I hear the relay "click" when attempting to activate the fuel pump through the Foxwell. Some reason the pump still would not turn on. Then I tried externally jumping 12v directly to the pump's pins and it turned on. While having 12v jumped I was able to start the car.
Is there some safety mechanism in the car that won't allow the pump to turn on even when receiving 12v from the connector?
Old 10-02-2022, 05:26 AM
Vanski's Avatar
Vanski
Vanski is offline
@rambatr56
Is your mini standard or automatic? Does the engine crank over with no start?
Old 10-02-2022, 10:02 AM
rambatr56's Avatar
rambatr56
Originally Posted by Vanski
@rambatr56
Thanks for the reply. It is standard. And yes it will crank but no start.
Old 10-05-2022, 10:56 AM
ECSTuning is online now
Received 1,965 Likes on 1,765 Posts
Are you getting fuel in the cylinder? Spark at the cylinder? That would narrow it down.
Old 10-07-2022, 05:42 AM
ICEE's Avatar
ICEE
ICEE is offline
Is there a switch on the clutch pedal so when you push it, it tells the car to activate things, like the fuel pump. Maybe this switch is bad?
2011 MINI COOPER 1.6L L4 Turbocharged Clutch Pedal Position / Starter Safety Switch | RockAuto
Old 10-07-2022, 05:52 AM
Vanski's Avatar
Vanski
Vanski is offline
@ICEE
NO, the switch on the clutch is just a safety switch for the starter motor and nothing else. The switch prevents the motor from starting up in gear
Lopanda
10-08-2021 09:25 PM
dogs_rule
07-22-2021 08:10 PM
xcmtber14
03-30-2020 08:27 AM
MCS_R56
09-09-2019 07:36 AM
Lopanda
04-30-2017 08:10 PM
Quick Reply: R56 r56 n18 fuel pump won't turn on
