battery specs
Old 10-19-2017, 07:29 AM
genik's Avatar
genik
genik is offline
battery specs
I need a new battery for my 2nd gen 2008 R56S... not sure if ill be getting the OEM, so im out on the look for a new one. What specs should the new battery have in order to meet the needs?
Old 10-19-2017, 07:55 AM
ECSTuning is online now
Received 1,966 Likes on 1,766 Posts
https://www.northamericanmotoring.co...ment-help.html
Make sure its the right group and on some newer Gen 2 MINIs watch for the IBS system.
https://www.northamericanmotoring.co...placement.html
Old 10-20-2017, 06:04 AM
bugeye1031's Avatar
bugeye1031
bugeye1031 is offline
Moderator
Be careful when you mount the terminals - esp the negative clamp as it can appear tight but the mechanism can get jammed. Also, some aftermarket batteries have slightly smaller posts, which can drive your IBS crazy....including resetting your clock, calendar, tripmeter, etc at random times.
